Step by Step guide to installing a Mark VIII motor in a 96+ GT. - Page 14 - MustangForums.com
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 08-06-2014, 10:31 AM   #131
BlackMage
BlackMage's Avatar
if you plan on keeping cruise, you will also need the 96-98 cobra cruise cable; or relocate the battery, and then relocate the cruise control module to where the battery one was, and your GT cable will work, but you'll need to splice in a bunch of extra wire so the connector reaches.
BlackMage is offline   Reply With Quote
Old 08-06-2014, 10:38 PM   #132
tinkercameron
sorry im just a little confused lol. but im using a 96-98 mark viii intake. not a cobra. so what throttle cables will work with it? can I just use my gt cable. and do I HAVE to have the imrc plates. or can I run it without it. sorry for all the questions.
tinkercameron is offline   Reply With Quote
Old 08-07-2014, 09:09 AM   #133
BlackMage
BlackMage's Avatar
Quote:
you mean a 97-98 mark viii intake. the 96 still has the TB in the rear. You will need to run a 99/01 throttle cable then.
and YES YOU NEED IMRC plates. if you're running the controller with them, you will need to wire them up. Or do what everyone else does and remove the butterflies within them and run it like that.
Old 08-08-2014, 12:53 AM   #134
tinkercameron
whats the difference in the throttle cables? why do you need a 99-01?
Old 08-08-2014, 01:43 AM   #135
tinkercameron
and would an 03 cobra throttle cable work?
Old 08-08-2014, 10:06 AM   #136
BlackMage
BlackMage's Avatar
the distance from the firewall is the biggest hurdle, but then the length of cable from the bracket to the throttle body is different too. the 99/01 cable is needed because the 97-98 mark viii intake is in the identical spot as the 99/01 cobra. That is the one that will work with it. The 03 cable will NOT work, because of where everything is located.
Old 08-09-2014, 11:06 AM   #137
1998Slow 'Stang
Default throttle cable
Just wanted to drop in and say, when I did my swap I used the 97/98 mark viii throttle cable with matching intake and throttle body without a problem, and have been running that way for close to 2 years now.
1998Slow 'Stang is offline   Reply With Quote
Old 08-11-2014, 05:27 PM   #138
jakemarsh7
So I'm installing the 96-98 cobra intake manifold, and for some reason some of the intake manifold bolts from the engine are too long. Any reason why?
jakemarsh7 is offline   Reply With Quote
Old 08-12-2014, 09:52 AM   #139
BlackMage
BlackMage's Avatar
Quote:
the intake manifold bolts from the engine are too long? which engine? not sure exactly what you are swapping in/on. I was able to use the mark viii bolts on my cobra manifold but had to mix and match until i got the right bolt lengths in the proper spots.
Old 08-13-2014, 09:16 AM   #140
jakemarsh7
Got it figured out, forgot about the spots under the manifold cover for the new manifold
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 01:47 PM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 11:49 PM
Window Motor(new) Issue: Opposite Direction HorsePower99 4.6L (1996-2004 Modular) Mustang 1 08-27-2015 12:29 AM
Window Motor(new) Issue: Opposite Direction HorsePower99 General Tech 2 08-26-2015 09:32 PM
Installing new hood jlopez07 2005-2009 S197 Appearance Section 1 08-21-2015 10:28 AM
98, 99, ac, cobra, coolant, delete, engine, fit, fuel, hose, mark, mustang, rails, remove, transmission, viii, wiring
