Step by Step guide to installing a Mark VIII motor in a 96+ GT. - Page 5 - MustangForums.com
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 07-11-2010, 10:05 AM   #41
liljojo4711
liljojo4711's Avatar
very nice to know. out of curiosity, y didnt u delete the egr and imrcc's? wouldnt that help free up some hp as well?
liljojo4711 is offline   Reply With Quote
Old 07-11-2010, 02:39 PM   #42
JC316
JC316's Avatar
Quote:
I was going cheap, so I didn't want to buy the IMRC delete plates and intake gasket. EGR stayed because I wasn't going to tune it for a while and I am in an emissions county.
JC316 is offline   Reply With Quote
Old 07-11-2010, 02:42 PM   #43
BraMas
BraMas's Avatar
IMRC delete is free if you do it yourself
BraMas is offline   Reply With Quote
Old 07-11-2010, 09:53 PM   #44
JC316
JC316's Avatar
Quote:
Gaskets are not. I was on a shoestring budget.
Old 07-11-2010, 09:58 PM   #45
BraMas
BraMas's Avatar
Quote:
The gaskets are reusable.
Old 07-12-2010, 11:11 AM   #46
liljojo4711
i have emissions also so i guess the EGR will be staying. is there a big advantage to doing the IMRC delete?
Old 07-12-2010, 12:26 PM   #47
JC316
JC316's Avatar
I guess I was impatient.
Yeah, you are in the same area of Texas that I am. TBH, you could probably get a plate and block off the EGR and they would never know it. IMRC delete gives you a bit more mdrange and high RPM power.
Old 11-23-2010, 08:59 PM   #48
crossfade
Default 4v swap
i had a couple of questions about the swap. After reading this article I got excited and bought a mark 8 engine for about 300 bucks. (great deal) I also got some long tube headers, etc. so here are my concerns now (should have done more research)
1) will the long tubes work with the swap?
2) instead of doing the IMRC delete I just opened them up from the back of the engine and locked them open with the metal shim that is located there. since it is out of the car it was quite easy to do. would this be ok?
3) i heard that the heat on cylindar 7 and 8 tend to get hot and blow plugs etc. since the engine is out of the car should I get a cooling MOD?
4) would a 99 aftermarket inlet tube work?
5) do you have pics of the heater hose fix issue?
6) would i have to swap the 96 gt fuel injector lines with the mark 8 engine?
thanks for any help you can give me. just like you, im on a shoe string budget. i hope to god this engine has no problems since i got it so cheap
crossfade is offline   Reply With Quote
Old 11-24-2010, 06:35 AM   #49
uberstang1
Chupacabra
uberstang1's Avatar
1) If the headers are for a 2v SOHC no they will not work because the 2v exhaust ports are circular and the 4v are rectangular.
2) You can tie them open but why not just delete them if the motor is out instead of having possible issues down the road.
3) The cooling MOD is a concern with C heads, specifically on 03-04 cobras. This motor has B heads.
uberstang1 is offline   Reply With Quote
Old 11-24-2010, 09:55 AM   #50
crossfade
you are awsome... thanks for the help man....
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 01:47 PM
timing issue 1987gt40ttopt 5.0L (1979-1995) Mustang 12 08-28-2015 11:49 PM
Window Motor(new) Issue: Opposite Direction HorsePower99 4.6L (1996-2004 Modular) Mustang 1 08-27-2015 12:29 AM
Window Motor(new) Issue: Opposite Direction HorsePower99 General Tech 2 08-26-2015 09:32 PM
Installing new hood jlopez07 2005-2009 S197 Appearance Section 1 08-21-2015 10:28 AM
98, 99, ac, cobra, coolant, delete, engine, fit, fuel, hose, mark, mustang, rails, remove, transmission, viii, wiring
