Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
please help!!! 2002 v6 into 1996 v6
Old 08-29-2012, 11:30 PM
kinzlerkid90
kinzlerkid90's Avatar
Default please help!!! 2002 v6 into 1996 v6
I want to put the motor an transmission from my 02 5 speed 6v. into my 96 v6 automatic. what all will have to be done an changed??
Posted from MustangForums.com App for Android
kinzlerkid90 is offline
Old 08-30-2012, 08:54 AM
uberstang1
Chupacabra
uberstang1's Avatar
If you have the complete motor and trans and the wirring and computer, simply move it all over to the 96. The motor and trans itself should bolt right up. And *** long as you have all the electronics and wirring you should be fine (im not sure the differences in that aspect between the two, no expereince with 3.8 swaps)
uberstang1 is offline
Old 08-30-2012, 05:38 PM
kinzlerkid90
does that mean the manual transmission from the 02 will bolt in automatic 96 without any issues?
Old 08-30-2012, 06:11 PM
LilRoush
LilRoush's Avatar
Don't do the computer and all.
Swap the motor, and get a modified fuel rail from Tom at Super Six Motorsports (Supersixmotorsports.com). Fuel system is return on the '96 and returnless on the 99-04 - so you'll need the custom made fuel rail to adapt the newer style heads to the older style fuel system.
If you are using the manual T5 out of the '02, it will all drop right in for you. You will have to have it tuned to get it all working together at it's best.
LilRoush is offline
HT
Carolina Regional Chapter
2115
09-27-2019 11:29 PM
Jordan123
03-26-2009 07:33 AM
ctgreddy
11-05-2007 09:43 AM
Quick Reply: please help!!! 2002 v6 into 1996 v6
