Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
5.0 from 87 fox to 98 gt that was a 4.6
Old 01-19-2013, 08:02 PM
shides20
shides20's Avatar
Default 5.0 from 87 fox to 98 gt that was a 4.6
Hey I am in the process of swapping my 5.0 302 from my 87 foxbody to my new body i just bought which is a 98 gt. I have the original wiring harness for the 98 still set up in the body. I am trying to find out if the wiring harness will work and fit correctly with the fuel injectors in my 302.
Does anyone have any input on this subject? Any more problems I could run into with the 98 harness and the older 87 302?
shides20 is offline
Old 01-21-2013, 07:05 AM
LilRoush
LilRoush's Avatar
You need the harness and computer from the '87. You'll need to account for all the electronics the '98 has that the '87 doesn't.
It's going to be a major pain to get it working.
May I ask why you are swapping? Is it a built 302?
LilRoush is offline
Old 01-21-2013, 02:38 PM
uberstang1
Chupacabra
uberstang1's Avatar
Just run a carb IMO, get a holley blue pump, get an an coupler fuel hat from lethal performance, few feet of an line to the carb, and be done.
uberstang1 is offline
Old 01-21-2013, 08:33 PM
Stevo86
Stevo86's Avatar
^ This, those engines are similar in that they are both internal combustion engines. Everything else is different. IOW nothing you have will work.
Stevo86 is offline
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: 5.0 from 87 fox to 98 gt that was a 4.6
