Coyote 5.0 swap into 2005 V6 - Page 2 - MustangForums.com
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 08-27-2013, 03:27 PM   #11
2007StangV6
2007StangV6's Avatar
Quote:
Originally Posted by Phansm72 View Post
Yessir , Im going to lay it out for anyone else looking to do the swap. I should be pulling the moor in a couple weeks. Just waiting on a few parts to arrive.
Are you building the motor yourself?
I know someone on another forums tried this swap out and everything worked out except for his gauges. Have you figured out a work around? That was a big thing that was holding me back.
2007StangV6 is offline   Reply With Quote
Old 08-27-2013, 03:34 PM   #12
Gary Ugarek
Gary Ugarek's Avatar
Buy a pillar kit and wire it in, the only gauges you need is RPM and speed everything else is worthless.
Gary Ugarek is offline   Reply With Quote
Old 08-27-2013, 04:38 PM   #13
Phansm72
The gauges are not a problem at all . Manuel over on s197forum did the swap into a 07 GT , the Ford racing control pack harness comes with an epas connector (AIM connector with 4 wires) that you wire into the wires at your OBD port that links the harness with your can network and you have gauges that work. He did it . Even the colors are the same on your factory harness.
Phansm72 is offline   Reply With Quote
Old 08-27-2013, 04:41 PM   #14
Phansm72
This is the pinout diagram for the Ford Racing control pack harness ,The connector that says In-line to EPas (aim for race car) if you check your OBDII port it has those colors , splice them in and itll comunicate with your CAN network. The V6 tach is the same as the GT and will work for the Coyote. I'll let u know when I get to the wiring if it works for me.
Old 08-28-2013, 07:32 AM   #15
2007StangV6
Saving that picture for future reference! Thanks Phansm! Now I have to start saving. Think i'm going to go and buy a block and just build from there.
Good luck with the build!
Old 08-28-2013, 08:11 AM   #16
Phansm72
How I got my Coyote , my buddy at ford called me and asked if I was interested In a' new 5.0. So I asked the details. A new 5.0 with 3000 miles on it came in with a slight rattle noise at 3500 rpm. The tech pulled the oilpan and discovered the number 7 rod bearing had a score mark in it , no other damage just number 7. They put a new motor on it. So I bought the motor for the core charge for $1000. I picked up a set of new boss 302R piston and rod kit and a boss 302 crank so now when it goes back together I'll have a completely forged internals , as it sits I have about $3500 n the motor with all accessories, intake etc.
Old 08-28-2013, 08:59 AM   #17
Phansm72
Old 08-28-2013, 09:00 AM   #18
Phansm72
Old 08-28-2013, 09:00 AM   #19
Phansm72
Old 08-28-2013, 09:01 AM   #20
Phansm72
Labor Day Weekend Special Granatelli Sales GT S197 General Discussion 5 03-25-2016 09:01 PM
Labor Day Weekend Special Granatelli Sales The New S550 2015-2017 Mustang 5 12-27-2015 07:28 PM
Owning a 2005 to 2009 Mustang GT mdj89 2005-2014 Mustangs 20 10-26-2015 12:53 PM
'14 5.0 VS EVO X JT76 Street/Strip 6 09-20-2015 12:32 PM
The Future of my GT vintageaion 2005-2014 Mustangs 2 09-08-2015 11:45 AM
