Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
408 CI 1995 GT
Old 08-05-2013, 11:46 AM
95 BLOWN GT
95 BLOWN GT's Avatar
Default 408 CI 1995 GT
Pulling the 302 out for the new engine....500hp + na twin turbo engine....will post install pics soon.
95 BLOWN GT is offline
Old 08-22-2013, 09:16 AM
95 BLOWN GT
engine is in , headers being built right now..
Old 08-24-2013, 01:46 PM
aode08
aode08's Avatar
Nice, not to be rude, but dont the 408 make 500HP by itself?
Adding two turbo's will bring you up to 600+ even on low boost.
aode08 is offline
Old 08-27-2013, 07:57 AM
89fiveeight
89fiveeight's Avatar
What's the benefit of running an electric water pump? Is there that much drag loss?
89fiveeight is offline
Old 08-30-2013, 09:12 AM
95 BLOWN GT
YES..before the turbos it will be a little over 500hp..with the turbos on e85 fuel i plan to be over 900 h.p.
Old 08-30-2013, 09:15 AM
95 BLOWN GT
there is alittle less drag due to not needing a pulley...i only need a belt to run the crank and alternator now...plus the electric water pump flows 55 gallons a minute a lot more flow then the stock pump....also i can flip a switch and circulate the coolant at the dragstrip with the car shut off to speed the cooling process.
Old 09-03-2013, 08:10 PM
89fiveeight
Nice didn't think about being able to run the pump without the motor on
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
Urambo Tauro
10-05-2015 09:37 PM
ccdguy
09-19-2015 05:20 PM
dalefrancis88
09-11-2015 07:15 AM
Urambo Tauro
09-07-2015 12:47 PM
Quick Reply: 408 CI 1995 GT
