Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
WILL THIS ENGINE SWAP WORK
Old 12-24-2013, 08:10 PM
oh3stang
oh3stang's Avatar
Default WILL THIS ENGINE SWAP WORK
my 03 stang i bought I knew had a blown head gasket and worst case it needed an engine. I've come across a couple free engines and wondering if it will work and what alterations if any are needed. I know the intake swap will be needed. I can get a 01 f150 4.6 out of the vehicle already or a 03 expedition 4.6 that is still in the vehicle. Should I do anything to them while they are out(water pump, head gaskets,etc).
oh3stang is offline
Old 12-25-2013, 05:23 AM
dawson1112
dawson1112's Avatar
I see no reason to swap the entire engine just for a blown head gasket.
How many miles on the o3 mustang? More than likely a new set of head gaskets will get you on your way.
Id still grab up both the " free " motors lol .
dawson1112 is offline
Old 12-25-2013, 01:08 PM
oh3stang
oh3stang's Avatar
160k, I changed the oil so I could test to see if the engine was damaged. I know the previous owner and they said the engine never overheated but at idle the engine sounded fine after the oil change but when you give it some gas I sometimes would hear a little bit of random valve knocking.Not sure if this would clear out or not. I didn't run it too long. Not sure if it is due to the oil not completely clear due to a little light milkyness left. The engine is not missing or anything. I don't want to do the head gaskets to find out I need an engine. I thought about going the Blue Devil route and seal the head to at least see if the engine is ok and then replace the head gaskets. Just trying not to do any unnecessary labor.
oh3stang is offline
Old 01-22-2014, 09:04 AM
Richardmustang91
Richardmustang91's Avatar
If looking to add more low end torque and more RWHP I'd opt to do an engine swap
Richardmustang91 is offline
Old 01-23-2014, 10:04 AM
oh3stang
oh3stang's Avatar
Thanks for the info. I am in the process of doing the swap. Tried the blue devil and it didn't work. Engine started knocking bad. PO must of overheated the engine too bad. Engine is almost out, dang there are some tricky bolts to take out. Looking forward to getting it on the road.
oh3stang is offline
Gary Ugarek
63
12-11-2015 02:01 PM
Gary Ugarek
08-26-2015 08:41 AM
classic69FB
08-12-2015 11:58 PM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: WILL THIS ENGINE SWAP WORK
