Motor Swap Issues - 97 into an 02 - MustangForums.com
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 03-11-2014, 11:31 PM   #1
CJCuster89
CJCuster89's Avatar
Default Motor Swap Issues - 97 into an 02
Alright so I've successfully swapped my motor. I got a 97 NPI for 400 bucks because I blew the bottom end of my old 02 motor. I know its a decrease in power, I just need transportation and a mustang that sounds like... well a mustang. So here are the issues I'm having.
The car starts and runs for as long as I want it to, however... The idle is high. It's sitting at like 1500 at all times. And if I rev the engine up to say like 4,000 it stays up there at 4,000 and gradually falls back to 1,500. When I say gradually, I mean like over 10 seconds.
Another thing is, my headers are getting red hot. They are glowing orange. And it's not every header. Only 2 on the passenger side.
My alternator isnt working properly either, but this is because the clip that goes into it is broken. I have a new one on the way but I'm not sure if this could account to my idling problem.
Any help or advice would be great and very helpful. Thanks.
CJCuster89 is offline   Reply With Quote
Old 03-15-2014, 04:24 PM   #2
CJCuster89
CJCuster89's Avatar
No one knows I guess?
Old 03-15-2014, 06:40 PM   #3
LilRoush
LilRoush's Avatar
Sounds like you have multiple problems.
If your PI top end is still good, I'd put the heads/intake on the NPI bottom end. Compression bump will scoop you a few extra ponies over the stock PI motor.
Hot exhaust can also mean a clogged cat.
LilRoush is offline   Reply With Quote
Old 03-15-2014, 06:53 PM   #4
Chromeshadow
I'd pull the spark plug on #2 and see if its running lean, should be light brown, if lean it will be white.
Chromeshadow is offline   Reply With Quote
2015 Mustang Expansion Tank Granatelli Sales The New S550 2015-2016 Mustang 15 06-23-2016 06:26 PM
trans swaps 97SN95GT 4.6L (1996-2004 Modular) Mustang 4 09-13-2015 10:45 PM
V6 Engine Ticking Nick Oliver V6 S197 General Discussion 2 09-05-2015 11:34 AM
Paint Flaws in New 2016 GT mustangchef New Member Area 7 09-04-2015 09:08 PM
New member and just bought my first mustang Luke9222 New Member Area 7 09-04-2015 07:46 AM
