Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
T5 bolt to carb 302?
Old 12-16-2014, 04:52 AM
Brandon W
Brandon W's Avatar
Default T5 bolt to carb 302?
I'm wanting to a motor swap and I know the motor will drop in and wire fine but I have a 98 t5 trans I wanna use. Will the t5 bolt up to the 302?
Brandon W is offline
Old 12-16-2014, 06:39 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm assuming your 98 T5 is from a V6. In which case I don't know for sure if that bell housing bolts to a 302. But, if it doesn't, finding a V8 bell housing shouldn't be a problem.
You'll have to do some research on that though, as a Fox bell housing is a little shorter than a SN bell housing. I don't know which one you'll need for your swap.
88 orangepeel notch is offline
Old 12-16-2014, 07:33 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Even if it's from a V8, in which case a 4.6, it's not even sure that it will bolt up.
I tempted to say yes but if I'm wrong, 302 bell housings are plentiful...
pascal is offline
Old 12-16-2014, 10:04 AM
PNYXPRESS
PNYXPRESS's Avatar
The T5 from the sn95 v6 cars is the same one used in the fox 5.0L cars so if you get a fox 302 bell it will bolt right up.
PNYXPRESS is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: T5 bolt to carb 302?
