Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
boss 351c in 1969 mustang
Old 08-27-2015, 09:13 PM
S'PortMustang69
S'PortMustang69's Avatar
Default boss 351c in 1969 mustang
Ok hope i put this in right section. I have a 1969 mustang with a 302 in it atm. A guy at work is going to sell me a boss 351c for pretty cheap but it needs a complete rebuild. I have been looking up info all day but Is there any major difference in a Boss 351 and a regular 351c? Such as do i need boss specific cam crankshaft pushrods pistons etc or will regular 351c parts do?
S'PortMustang69 is offline
Old 08-28-2015, 01:07 PM
movielover40
movielover40's Avatar
I'm sure all the parts in the Boss were more heavy duty than regular 351.
movielover40 is offline
Old 08-28-2015, 02:45 PM
S'PortMustang69
Well picked up engine and looked up code which was D2AE-CA on block which according to research it was cast in 72 so its not a boss 351 and heads was like D3AE which would be 73. Still pretty excited cause got engine for only $200 but evidence says its not a boss
Old 08-28-2015, 04:24 PM
movielover40
Still a very solid motor with 4 bolt mains.
With those heads you can run unleaded gas in it and not have to worry.
Old 08-28-2015, 05:17 PM
S'PortMustang69
Sadly it is 2 bolt mains
Old 08-30-2015, 08:27 PM
pascal
S197 Section Modder-ator
pascal's Avatar
351C have a tendency to eat cams so I'd strongly suggest to go with roller cam and tappets.
Machinists in the days used to drill holes in the block's valley for more lubrication to help with that issue...
Keep in mind also that it's a heavy block so I would put heavy duty springs on the front end.
Good luck on the build...
pascal is offline
chain
08-17-2015 08:52 AM
raven_ghostwolf
08-16-2015 08:16 PM
daytooday
08-11-2015 09:22 AM
dseg
08-08-2015 09:00 PM
Quick Reply: boss 351c in 1969 mustang
