Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
Remove headlight knob
Old 08-18-2007, 02:11 PM
daniel5455
daniel5455's Avatar
Default Remove headlight ****
Anyone know how to remove the headlight **** on a 77 mustang cobra II. I think mine is glued on cause i tried to see with a mirror if there is a clip holding it and i dont see one. I tried pulling it and was afraid i will break it. any suggestions.
daniel5455 is offline
Old 08-18-2007, 05:02 PM
Turbo II
Turbo II's Avatar
Default RE: Remove headlight ****
Ah tnis one always catches people with Fords! To make it interesting, Ford switches of this vintage have a small pushbutton located on the switch itself. (see pic)
You have to be a bit of a contortionist to get to it and small hands are best. Disconnect your battery first if the **** is going to be off for some time. Turn the headlights all the way on first, then reach up under and behind thedash, and push in the little button (once you find it with your fingertip!) and then pull the switch all the way out. The **** will come out with the entire shaft. To replace, just push it back in all the way, it should re-lock itself in position.
Hope this helps, I know I took a while to figure it out on my first Ford ('72 pickup)
Francis "Turbo II"
Turbo II is offline
Old 09-17-2007, 10:43 AM
DonA
DonA's Avatar
Dissusing the ansestory of the guy who designed this item helps to relieve the frustration
DonA is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Remove headlight knob
