Hi there!
I connected my stereo. It' spretty easy. look at your harness in your stereo compartment you need to find your v power wire that is usually red. If its not red than test all the individual wires with a voltage meter and the hot wire will read 12 volts. My hot was red so yours should be also. Connect your stereo red and yellow or orange wire (depending on what type of stereo you have) to your 12 volt wire in your car and connect your black wire of your stereo to the black ground in the car. The black wire is easy to find . The rest of the wires for yours peakers will be two wires forv each speaker one having a colored wire with as tripe than another wire matching that wire with no stripe. connect same colored car speaker wires to any of the speaker wires on your stereo make sure youconnect striped with striped and solid with solid . Its not going to matter what speaker wires you connect each car speaker wire with because the stereo is going put the same power output to each one anyways. Hope this helps.
Sam
