Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
V8 T-5 swap bellhousing id
Old 06-09-2013, 04:25 PM
75moosetang
75moosetang's Avatar
Default V8 T-5 swap bellhousing id
Hey All,
Im planning on putting a manual t5 behind my 302. ive seen this bellhousing on ebay but not sure if it is for a mustang II. i cannot find and id chart to reference the casting #s.
my question is, will this bellhousing fit in my mII
http://www.ebay.com/itm/Ford-302-Bell-Housing-D6ZA-6392-BC-F-truck-Mustang-II-cobra-/290928388483?pt=Motors_Car_Truck_Parts_Accessories&hash=item43bcaee983&vxp=mtr
Thanks
75moosetang is offline
Old 06-10-2013, 10:08 AM
roystere
roystere's Avatar
That's a 76 part number (D6ZA), so it should fit your MII. I'm not sure of the dimensions as the listing posted Ford Truck as well. Does the seller know what it came out of? Either way, the opening for the transmission will have to be machined to make it larger to accept the T5 and you'll have to have a spacer made for the input shaft bearing that's in the end of your crank, unless you're using a 94-95 T5 which is supposed to have a longer input shaft. Go to www.mustangii.net and look in the Tech Section as there is a very good how to article on installing a T5 using a MII bell housing.
Good Luck!!
roystere is offline
Old 12-06-2016, 02:04 PM
Chiss
Chiss's Avatar
I got a T-5 bell out of a early 90's GT for my project. Read some were that a 164 tooth bell was to big for those chassis, But no problems with the 157's. The T-5 bell will solve all the milling and spacing. Got mine off E-Bay for $125.
Chiss is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: V8 T-5 swap bellhousing id
