light flicker
RE: light flicker
ok do u no how to add that wire on like could u explain. sometimes it gets really bad tho like the battery gauge goes from being inbetweenthe M and the Ain the word normal on the gaugeto going past the N an the battery light comes on everytime the bass thumps. would that be the alternator not charging the battery fast/good enough
RE: light flicker
what you need to do is remove the stock wires from the alt to battery, battery to ground and engine to ground. upgrade to 6 or 4 gauge wire. this will let more power flow without restriction. if you dont know what your doing find someone who does, fairly simple. this will take care of your issues. do you know how much peak amps your pushing? if you dont use a meter and find out and i can tell you if upgrading your wires is enough or if you will need a cap anyways.
RE: light flicker
do all of the above if you have a high wattage system and it sounds like you do. buy a new alternator, heavier gauge wire at the battery and cable going to your amps and get some capacitors if you still have problems. the capacitor provides extra energy when the bass hits.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
