min. octane?????
RE: min. octane?????
I believe most everything is a 87 oct. Normal the only thing that would force you to raise the octane in your fuel would be if you raised the compression ratios. After market parts such as a new wiring system, intercoolers, and anything not dealing with the engine itself will not require an octane boost.
Octane is a level of rating fuel. It measure how slow it burns, but more importantly what tempature it will pre-fire (explode due to heat and not spark). When you have a high compression engine like a stroker the fuel will heat up more then normal at the top of the compression stroke. If the doesn't have the needed octane it will pre-fire and you get bad engine knock.
So on less you are changing the compression, which I am not sure if supercharges and turbo do or not, you should be fine with the stock 87 min.
here in florida we have 93. im sure that they mean the highets octain available which is usually 91. i dont know alot about thenew mustangs but inst the90mm pretty big for NA? are you going turbo or supercharged?
I DON'T KNOW WHAT IF ANY CHARGERS IN THE FUTURE... BUT FORD RACING TOLD ME IF YOU INSTALL THERE 90MM AIR INDUCTION I WOULD NEED TO FLASH THE COMPUTER AND RUN ONLY HIGH OCTANE PUMP FUEL FROM THERE ON OUT.
i wouldnt run anything but the highest octane if i were you. if you drive your car alot it becomes a bit pricy but it is def. worth it. im pretty sure a stock stang calls for 87 min. atleast thats what mine calls for, but i run 93 anyways.
I'm not sure what benefit you are getting from running a higher octane than needed....in fact I was told by Ford not too, except in my 67 which has a Ford Racing crate motor that calls for it. Can someone explain to me why you would run higher than 87 in a factory spec engine? thanks
