Twin Turbo 05 GT
RE: Twin Turbo 05 GT
ORIGINAL: 2000Si
perhaps he's waiting until he can afford to build the bottom end?
ORIGINAL: OUZBnd
Why would you put twin turbo's on for only 3lbs of boost? WTF is the point?
ORIGINAL: DaGGer
if you bump that psi up a bit then you would have a lot more than just 357....a lot more
ORIGINAL: OUZBnd
I hope he's going to up it at some point... otherwise it seems like a waste, other than the coolness factor[8D]
ORIGINAL: 2000Si
ORIGINAL: OUZBnd
That off road setup is where I'll be living because there are no smog considerations in Iowa! Hooyah!!
Well, before you start cranking the boost, you'll have to build up stronger internals with a lower compression.
I don't know a thing about the 05s but my guess is that they aren't designed for boost right out of the factory.
357 is kinda sad, a stock Cobra puts out more than that.
ORIGINAL: Stinger
grounpounder must be a infantry guy fo sure.. i smell 11 B, sniff sniff!
