Twin Turbo 05 GT
#21
RE: Twin Turbo 05 GT
ORIGINAL: OICW
Well, before you start cranking the boost, you'll have to build up stronger internals with a lower compression.
I don't know a thing about the 05s but my guess is that they aren't designed for boost right out of the factory.
357 is kinda sad, a stock Cobra puts out more than that.
#22
nice lookin 05 GT you got there man. They have similar set ups for the Fox Body 5.0's but the horse power rating is off the wall 1,000-1,900 hp (depending on what turbos are used). Turbo Kits is the name of the company you can get it from. There right near where i live in CT. Wow its nuts what kind of a car you can have if you have dough.
#23
ORIGINAL: groundpounder
??? [sm=dontgetit.gif] I hope it's some sort of compliment, but I have my doubts[sm=smiley13.gif]
ORIGINAL: Stinger
grounpounder must be a infantry guy fo sure.. i smell 11 B, sniff sniff!
#25
Absolutely. They just want to do it a little at a time, working the tweaks out along the way. This is big time terra incognita, so they are being careful with their $30,000 experiment. They will take it to 8-9 psi the very next time they make a pull, which could be any day. Later this spring, they are going to bump the psi up until something breaks so they will know the limitations.
Then I bet they go fully forged, port matched, cams, valve jobs and heck knows what else and make over 1,000 HP
#26
ORIGINAL: OUZBnd
Why would you put twin turbo's on for only 3lbs of boost? WTF is the point?
N2F
#27
ORIGINAL: New2Ford
Thats 3 lbs. on each side,you guys have to remember its TWIN turbo.So its six pounds of boost,which is where I just about start at with a TT project,unless I start with forged internals.
N2F
ORIGINAL: OUZBnd
N2F
#28
ORIGINAL: OUZBnd
You sure about that? I didn;t read the link, but i just assumed the boost was overall boost - seems logical to mesure it overall to me.
ORIGINAL: New2Ford
N2F
ORIGINAL: OUZBnd
N2F
N2F
#29
I'm with you guys - I want to see this thing FLY. But if you think about it, the biggest waste of time would be to damn the torpedos and boost this thing up and blow it up. THAT would be a waste of time. I mean, they've only been working on it like a month and a half.
They're chomping at the bit to do a 8-9 psi run (and that is not measure per side, BTW), they are just waiting on SCT for some tweaks. I can't wait! I'd like to think maybe they're conservative at 450 rwhp, but they are rarely off on their initial estimates. Fofitty at the wheels would be like 520 at the crank. KEWL!
