All yee interested in a stall
RE: All yee interested in a stall
ORIGINAL: IntruderLS1
When the stall converter "locks," it is physically attaching itself, so you have as close to 100% efficiant as possible. It saves on gas, and saves on the life of the Converter.
Correct....since you are still working through fluid you will never be 100% like a standard. In a since the Torque Coverter is always slipping. This will enable him to get a good launch without having a clutch.
ORIGINAL: jdaniel
You have to break an 8.2 to run with muh ride so I besta see some good results.
Hell, I don't know how it's gonna run. The guys on LS1tech are going 8.0's - 8.3's with the same mods, but they're running mid 12's. So who knows.
Well you should be okay. I took my best 1/8 and calculated my 0-60mph to be right at 4.2 seconds. That was a track run though... I would probably never see that kind of take off on the streets.
ORIGINAL: jdaniel
how did you figure that out?? i got 7.763 and was at 92.13mph at the 1/8. do you need any more info to figure out 0-60 time?
