Go Back   MustangForums.com > Other > Mustang Videos
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-06-2009, 11:10 PM   #1
P.S.I.cho
1995 Ford Mustang
Default my short 03 vid
heres a short video of my 2003 cobra, i have been changing things slowly since i bought it getting bugs and kinks worked out of it hopefully it will ready of some 19 psi videos other then the dyno soon.
__________________
95 gt vert: 331 stroker, d-1sc @ 10 lbs,582 rwhp 511 ft. Tq
2003 sonic blue cobra KB 2.2 @ 19psi,supporting mod, solid 8.8 601 rwhp 584 rwtq
F/S 99-04 anderson pms piggyback tuner, 331 stroker, stock t-5, stock 8.8" 3.73 rearend
http://www.cardomain.com/id/moocow_v
my videos
http://videos.streetfire.net/uploaded/vertstang95.htm
http://www.youtube.com/watch?v=NdptbEq5UJU
P.S.I.cho is offline   Reply With Quote
Old 08-07-2009, 12:02 AM   #2
apeterman
1996 Ford Mustang
apeterman's Avatar
Vehicle: 1996 Mustang GT
Nice runs and HP.
apeterman is offline   Reply With Quote
Old 08-07-2009, 12:36 AM   #3
luckythirteen13
luckythirteen13's Avatar
how much hp were you making when you made those passes?
any plans for more power?
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 08-07-2009, 06:03 PM   #4
P.S.I.cho
1995 Ford Mustang
when i bought the car at 15 psi this is the dyno sheet picture i got, i cant tell if its 461 or 481 rwhp, the car was dyno'd in IL and is from Iowa, i brought it to Colorado 5,800 feet above sea level and still ran 12.4 so not sure how much the altitude effected the power never dyno'd it here at 15psi made a few 1/4 mile passes and then did the pulley swap. in iowa the previous owner said he never took it to the track but on the street it beat a 11.80 car.
as long as the car runs good at 19 psi its going to stay here if i cant get the 1/4 times i want ill probly be going back down to 15psi and a 50-75 shot of nitrous or maybe a snow meth kit. ive been having problems at 19psi from belt slipping to spark issues, hopefully we got it worked out this time, added 100mm snubber pulley next to the s/c from the 90mm pulley it had and stepped down to a colder plug. actual hp numbers are probly slightly less like i said in the video the air was PERFECT for the dyno.
15psi dyno sheet in iowa
__________________
my videos
Old 08-07-2009, 07:13 PM   #5
kennebell92conv
kennebell92conv's Avatar
Vehicle: 92 ford mustang kenne bell 2.2
nice runs and badass stang
kennebell92conv is offline   Reply With Quote
Old 08-10-2009, 06:04 PM   #6
95 BLOWN GT
95 BLOWN GT's Avatar
Vehicle: 95 mustang gt
great vid.. cool ride..what kind of 60 ft are you getting ?
__________________
1995 MUSTANG GT
offroad h pipe w/ flowmasters
4.10 gear eaton posi 31 spline mosers
flaming river man. rack
upr chrome moly k member - a arms
coil overs on front w/strange adjustable struts
battery in trunk elec. water pump
driveshaft loop . subframe connectors
racing seats 8pt. chrome moly cage
rear seat delete
wolfe upper and lowers - anti roll bar
torque boxes welded - strange adj shocks
next on list trans rebuild
95 BLOWN GT is offline   Reply With Quote
Old 08-10-2009, 07:49 PM   #7
P.S.I.cho
1995 Ford Mustang
that was with a 1.8 60 ft. on nitto 555R's with about 12 psi of air in them (yea i know they say dont run under 15) havent had too much luck getting a good 60 with 19 psi yet, spinning like a mofo but ill figure it out, i havent been to the track too much with the car since i just bought it not too long ago :S only put 2,500 miles on it since
__________________
my videos
Old 08-11-2009, 05:02 PM   #8
nitrous_fed_03gt
nice video. are you running street tires though??????
nitrous_fed_03gt is offline   Reply With Quote
Old 08-11-2009, 09:41 PM   #9
P.S.I.cho
1995 Ford Mustang
yes nitto 555r's are a drag radial but they are very hard rubber compound for a drag radial unlike the MT et streets wich are very soft.
__________________
my videos
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
