K&N air filter & Intake Turbine fan for $70.00
I just bought a 2015 Mustang 3.7L V6 6 speed auto paddle shifter. The first thing I ordered was a K&H air filter 33-5029 from K&N online, then I ordered a Intake Turbine fan( ebay search car intake turbine fan 11" dim output 55,000 RPM from $5.00 to $25.00 there all the same). I removed the filter intake cover from the hose put the small rubber spacer on the outlet of the turbine & the large rubber spacer on the intake on the fan pull out on the coil rubber hose turn the fan side ways & slide it in the intake hose sliding the last inch into the hose make sure that it secure (if not pull to opening of the hose turn around to were the back is facing you drop a 4 drops of superglue at top, left, right, bottom of the large rubber spacer hold in place a few moments letting the glue to make contact & is secure in place) then install the air filter cover into the coil rubber hose is secure tighten the hose clamp secure the air filter cover. I drive 120 miles round trip keeping the engine RPM high so the throbble body suck as much air as it can adjusting the air/fuel ration. I did the same combo to my 2004 Crossfire 3.2 V6 & had quick acceleration & HP poor mans supercharger for $70.00 it works the same except belt driven this is force air driven.
http://www.ebay.com/itm/Car-Fuel-Gas-Saver-Supercharger-Turbine-Turbo-Charger-Air-Intake-Single-Fan-/261742545361?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cf11249d1&vxp=mtr
I ordered a Intake Turbine fan throbble body suck as much air as it can adjusting the air/fuel ration. I did the same combo to my 2004 Crossfire 3.2 V6 & had quick acceleration & HP poor mans supercharger for $70.00 it works the same except belt driven this is force air driven.
