Need some help
Need some help
Hello, I need some help! I own a 65 mustang 289 v8 4 bbl that refuses to start. I didn't drive the car for 8 months due to my delpoyment and now it just doesn't start. I replaced the fuel pump change the battery and even removed the old gas I noticed a wire that had wondered off from its location. I attached a picture of the wire. If any has any advise please send it my way.
Jake
Jake
Looks like a spade connector that might go to the electric choke. It's a rather large gauge wire for that though. I'd does look like your choke is missing a wire if I'm seeing that tab right. Does it reach the choke ?
Even then, your motor should still run, or at least try to start. Is it not even firing at all ?
Welcome to the forum, but this thread might get moved to the Tech Section.
Good luck
Good luck
but.........did you check spark at the plugs, or to see if the carb is actually getting fuel, for all you know that wire has been disconnected for the last 10 years and was unnoticed. diagnosis is a science, assuming that that wire is the issue without determining what the actual cause for the no start is is a waste of time. you ask for help.......this is it.
DerekShiekhi
05-06-2016 07:30 PM
04-12-2016 09:36 PM
