Rear Tire Leaning Inward / \
Old 01-25-2017, 07:34 PM
blackmc1
blackmc1's Avatar
Cool Rear Tire Leaning Inward / \
i have a 2000 mustang gt , and I just put brand new tires on it 1000 miles ago and I just noticed the inside of my rear tires have worn down drastically, seems like the top of them are leaning inwards / \. please help
blackmc1 is offline
Old 01-26-2017, 08:38 AM
proeagles
proeagles's Avatar
Looking forward to seeing the answers on this one. This car has a solid rear axle.
proeagles is offline
Old 01-26-2017, 11:35 AM
Urambo Tauro
Urambo Tauro's Avatar
Welcome!
Could be bent axle tubes or bent axle-shafts. If the tire wear is limited to the inside tread, and the camber does not change with rotation of the wheel, then I'd lean towards axle tubes. Check it with a straight-edge. Sometimes they can be straightened and reinforced; other times the axle assembly has to be replaced.
Urambo Tauro is offline
Old 01-26-2017, 12:14 PM
movielover40
movielover40's Avatar
Never heard of this with solid axle car.
movielover40 is offline
Old 01-26-2017, 12:27 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Bent axle tubes or the top inner tire leaning inwards like that? Bent axle tubes can be from curb checking or getting hit in the rear quarter panel. They will cause the tire lean the OP is talking about.
Derf00 is offline
Old 01-26-2017, 03:02 PM
proeagles
proeagles's Avatar
NASCAR does it all the time to change the rear camber. However, a stock car should not be bent. If the wheels where slammed against a curb at some point I would have thought there would be positive camber and the outside of the tires would be worn out.
