Go Back   MustangForums.com > Vendors & Sponsors > Obsessive Detail
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-19-2007, 09:13 PM   #1
G man
Default Fine scratches in clear coat...it looks like
I just had some silver stripes painted on a 06 GT.. Looks like the body shop went and "roughed" up the entire hood rather then just the 24" area in the middle for the stripes. Now it still shines great but when I look eye level with the hood I can see fine scratches on the entire hood outside the stripe area which is tungsten grey.
It's not horrible but if you look closely you can see it was obviously roughed up and it was perfect before.(I know they wet sanded the edge of the stripes so more flush that is ok)
I am buying the PC from you. What pads etc. do you recommend and do you have any advise? thanks a bunch.
G man is offline   Reply With Quote
Old 08-19-2007, 09:52 PM   #2
Juztang
Send a message via AIM to Juztang
Default RE: Fine scratches in clear coat...it looks like
If you are going to get the PC I would go with the Optimum or Pooroboy's PC kit. Both kits have medium and light cutting polishes. They also come with the PC, backing plate, white polishing pad, orange light cutting pad, and gray finishing pad. The orange pad will be used for medium to heavier swirls and the white polishing pad will be used for light swirls and regular polishing. The gray pad is used for applying glazes, sealants, and waxes.
Most likely you will have to use the orange light cutting pad with a medium abrassive polish and then step down to the white polishing pad and a light polish. Hope this helps and let me know if you have anymore questions.
__________________
http://www.obsessivedetail.com Your source for high quality detailing products and accessories.
2004 Saleen S/C #170
Juztang is offline   Reply With Quote
Old 08-19-2007, 10:20 PM   #3
Denny Carlton
Denny Carlton's Avatar
Vehicle: 2006 Mustang V6/4.0 F/I
Take the car back to the shop and talk to the owner about what his workers did to your car. Be nice at first, then open up a can of verbal whip-a**.
__________________
The Polish Snail!
V6/4.0/Auto
Vortech V3 Intercooled
SCT
Jba header
Dual FlowMaster AT
Magnaflow X pipe
Powerhouse DS
US Strange Gears 3.73 & T-lok
Steeda sport springs
LCA & Bracket
UCA
Adj.Pan hard Bar & BraceGT-R swaybar
D-spec.shocks
17x9 Chrome bullitt
Nitto NT555
Powerslot
HPS hawk pads
303 rwhp/300 rwtq/afr 11.9/psi 9.7
Denny Carlton is offline   Reply With Quote
Old 08-20-2007, 09:51 PM   #4
G man
Thx for the info PP done. Will I see a MF discount?
Old 08-21-2007, 07:28 PM   #5
Juztang
I threw in a couple of freebies with your order for you!
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
