Hey i was wondering it says on the website that you don't need to let the wet obsessions wax cure/haze over before wiping off. My question is, is it ok to let it haze, does it give it a better application to the paint if you let it sit for a few minutes? and does it require you to wipe it off right away? Ive just never seen a wax that you don't let it haze over before you wipe it off.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
92lx frpp 5.0 gt40, vortech s-trim 14# Mighty mite m2 c4, Trickflow track heat, 4800 tct stall, 3.73 rear gears, true-trac, moser 31s,Wilwood drag brakes, strange 10-ways on all 4, weld prostars, M/T's & skinneys, Team Z Motorsports front k member kit and coilovers, eibach drag springs dual airbag
best Et-10.96
best mph 123.60 still got some in it. leaving it in the 60'
3145lbs with driver
Winter objective:10point,mini tub, team z rear suspesion, kirkley seats, 29.5x12.5 m/t et streets
You can actually put it on a panel and then wipe right off, you can also put it on the whole vehicle and then come back and wipe off. I think it does look wetter if you let it sit for a while. Also Wet Obsession gets even better looking with layers.
You can layer it about 30 minutes after the first coat. After the second layer I would wait about 24 hours before adding any layers. This wax looks wetter and deeper with additional layers too!
