New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Other > Off Topic
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-10-2009, 12:57 AM   #141
FORD TOUGH
1994 Ford Mustang
FORD TOUGH's Avatar
Vehicle: 1994 Mustang GT
Quote:
Originally Posted by 99BlackPonyGT View Post
thats fake...diesel sound slip over layed on the vette video...cummins I6 wouldnt fit in the vette
IDK they put them in Rangers but there is no black smoke.
FORD TOUGH is offline   Reply With Quote
Old 01-10-2009, 12:58 AM   #142
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
Quote:
Originally Posted by FORD TOUGH View Post
IDK they put them in Rangers.
so? cummins is too tall for a vette....ignoring that, the c5 in that video is the same one in all the other 1320videos and its not a diesel in any of the other ones...its a fake, sorry to burst your bubble
99BlackPonyGT is offline   Reply With Quote
Old 01-10-2009, 01:00 AM   #143
TAoW1939
TAoW1939's Avatar
Quote:
Originally Posted by 1990CamaroRS View Post
true, but i've yet to see EUI's on a light duty pickup. it all seems to be hydro-mechanical injection. i'd love to see what could be done to a light duty truck with EUI's though
They might work, but it would take a bigass cam to get enough pressure on the injectors. The Common Rail with Piezo Injectors is the way to go, 36000 psi fuel pressure with up to 7 injector firings per cycle hell yeah.
edit, how about dropping a Series 50 into an F150 or 250, sure it will shake itself to pieces but 1200 ft/lb of torque from an I4 stock isn't bad. Thats if you can keep the pistons from shattering the cylinder walls (which they do ALOT).
__________________
"A man has no principles or morals, if he does not act with great conviction upon those which he claims to have."
"For some reason beyond all rational and logical thought, an arcane belief continues to exist. That the actions of one somehow warrants the limitation, or even the revocation, of the unalienable liberties of another. While the intentions behind this rationale could be considered noble, it is unexcusably naive, and must be resisted at all costs."
TAoW1939 is offline   Reply With Quote
Old 01-10-2009, 01:02 AM   #144
FORD TOUGH
1994 Ford Mustang
FORD TOUGH's Avatar
This better not be fake. http://cars.about.com/b/2007/04/01/c...r-for-2009.htm
Old 01-10-2009, 01:03 AM   #145
99BlackPonyGT
aka Negative Nancy
seeing as how that was posted in 2007 aiming for "next year" being 2008, which has come and gone....ide go ahead and say that yea its fake... 2009 vettes are already out and theres no diesel
Old 01-10-2009, 01:07 AM   #146
FORD TOUGH
1994 Ford Mustang
FORD TOUGH's Avatar
I didn't pay attention to that I just typed in diesel vette in yahoo. Ill go look on gms website and see if they have anything on it.
Old 01-10-2009, 01:16 AM   #147
1.5LofFury
1990 Chevrolet Camaro
1.5LofFury's Avatar
Vehicle: 1990 Camaro RS
it's a matter of weight. the 50 is around 2800lbs (iirc) so it would be too much for any light duty truck to take. you could probably fit it in a medium duty truck (Kodiak/Topkick, F550 up) and not have too much of a problem with the weight. that's actually a swap i want to try. and they don't shake THAT much (at least when the balancing shafts are correctly timed). also, just install thicker cylinder lines and slightly smaller pistons to stop the shattering problem (would the cylinder wall problem be common with the 60 Series too, considering they are the same liners and pistons, just two more on the 60??)
__________________
The slowest Camaro on Mustangforums
1.5LofFury is offline   Reply With Quote
Old 01-10-2009, 01:16 AM   #148
FORD TOUGH
1994 Ford Mustang
FORD TOUGH's Avatar
They are making a diesel corvette, it comes with a 6 speed Alison transmission and V5 trailer hitch.
Old 01-10-2009, 11:06 AM   #149
TAoW1939
TAoW1939's Avatar
When I worked at W.W.Williams, the only 50s we saw were in CCT buses, and they were in the shop all the time. It is a horrible engine design, they simply took a Series 60, cut 2 cylinders off and threw a pair of balancer shafts under it, and thats it. The shafts aren't nearly heavy enough to compensate for the 4 gigantic pistons getting thrown around. Self destruction on the 60 doesn't happen because the 6 pistons balance each other out really well, but the 50 would throw them straight through the liners. Detroit should have just taken the 60 and made it smaller overall, not just cut the rear 1/3 of it off and do nothing else to it. It really does feel like a I6 that is missing 2 pistons when it is running. Now it would still be cool to put into a smaller truck, they actually only weigh about 2200 pounds, so a 250 or 350 could handle it if properly braced. And it wouldn't be hard to get 2000 ft/lbs of torque out of it with a little reprogramming.
__________________
Old 01-10-2009, 12:56 PM   #150
1.5LofFury
1.5LofFury's Avatar
i've yet to see a ISB swap in a Ranger. i've seen plenty of 4BT swaps, but never an ISB. that engine is just a little too long for the Ranger.
the swap i'd LOVE to see though would be a 12v71 Detroit in a pickup
__________________
c5, corvette, duramax, mustang, swap, swaps, trade, vette
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
