Unless you are expecting some fish babies, I don't unstand why you would want a "brush pile" in your tank. I'm trying to visualize it done tastefully, but I can't..
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
boil in in a pot of water for 2 hours, and if the whole log cant fit in the pot, don half for 2 hours and the other half for another 2 hours...
then sit it in a pot of dechlorinated water for 2 weeks... or untill the log stops leaking stain( turning the water green/brown )... then put in your tank...
heres my tank
+1 Boiling water then dechlorinated water until the water it's soaking in stays "clean" Dechlorinated is very important because the wood will absorb whatever chemicals are in the water and then leech it into the tank water thus killing your fish.
I've done that method for putting sea shells into a fresh water aquarium as well. Only difference was I put them in a bleach bath for about 15 minutes, then boiled, then soaked.
Marine shells into a FW aquarium is a bad idea, as the Calcium and lime are pulled into solution and raise pH.
As for this wood decore topic, use old dry wood to start with, soaking it long term removes tanins. Make sure to change the water it's soaking in so you pull out as much as possible. You'll still see some residual, but it won't be nearly as bad. Boiling takes care of possible parasites or other contamination.
__________________
~Matt Race car: 2000 Roush #5004 Shark hauler: 2001 Explorer Sport 4.0L Show car: 1970 Mach 1 351
ill check out the creek by my house and get some smaller drift wood or branches that are just soaking in there since i dont wanna huge hunk of wood, and ill put it in hot water for a few days
Make sure the creek isn't being fed from a treated or polluted pond/lake in your area.
Have you looked on E-bay for driftwood packages?
BTW, switch to saltwater. So much more rewarding.
ehh im not ready to deal w saltwater setup, idk where this creek actually starts, it weaves thru the forrest preserves of 3 diff towns, its sumwhat deep in the woods
