What oil do you use? - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 08-20-2014, 11:11 PM   #11
rmodel65
Yukon Cornelius
rmodel65's Avatar
could definitely be the fuel pump. or maybe just the drain back valve failing. try turning the key on and off a few times and see if it starts quicker. if you do replace the pump only buy an OEM motorcraft or a Walbro. if you buy any cheap pumps it will last about a month or maybe 3 if youre lucky
rmodel65 is offline   Reply With Quote
Old 08-21-2014, 07:22 AM   #12
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Motorcraft synthetic blend.
For lawnmowers and small engines 30W non detergent.
fastbackford351 is online now   Reply With Quote
Old 08-21-2014, 07:46 AM   #13
audioAl
audioAl's Avatar
I use 5 qt of Castrol Edge & 1 qt of Lucas oil synthetic stabilizer. I need to change mine in the 2014 as I just turned 5,000 miles.
audioAl is offline   Reply With Quote
Old 08-21-2014, 10:49 AM   #14
Mishri
Mish-ogynist
Mishri's Avatar
I use mobil 1. Motorcraft is supposed to be good too.
I use 5w-20. Why? because the difference between 5w-20 and 5w-30 is like 8 degrees. unless you have a precise thermometer you wont know which works best, but they both work well in the 190-210 temp range. So it doesn't really matter anyway.
I should use something like 10w or 15w being so cold here, but I only change my oil once per year in the spring, I don't drive it much. (Drive the truck more in the winter).
Mishri is offline   Reply With Quote
Old 08-21-2014, 12:21 PM   #15
akiba17
Not 100% a dick
akiba17's Avatar
You should still change it bi yearly Mish.
akiba17 is online now   Reply With Quote
Old 08-21-2014, 12:38 PM   #16
Tubra
Tubra's Avatar
Used to use mobil 1, when I got my '12 GT I decided to try Royal Purple and noticed an improved overall smoothness and bump in power. I wanted to go for amsoil, but it was difficult to find.
Tubra is offline   Reply With Quote
Old 08-21-2014, 01:15 PM   #17
Mishri
Mish-ogynist
Mishri's Avatar
Quote:
http://www.fordservicecontent.com/Fo.../11musog1e.pdf
1 year or 10,000 miles is the recommended oil change interval noob. I only have like 11,000 miles and owned it for 3 years. No way would I change oil after 1,500 miles.. tis silly.
Old 08-21-2014, 02:55 PM   #18
Derf00
You got it backwards Mishri. The colder the temp, the lower the first number should be.
Derf00 is offline   Reply With Quote
Old 08-21-2014, 02:59 PM   #19
HRnB
Administrator
HRnB's Avatar
That's because Mishri is an idiot savant.
HRnB is offline   Reply With Quote
Old 08-21-2014, 03:00 PM   #20
Derf00
Touche.
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
Ticking coming from 4.6L. What could it be? Shadow7874 2005-2014 Mustangs 4 09-24-2015 10:06 PM
Oil change belam Oil and Oil Related Topics 4 09-24-2015 12:29 AM
Need Help ??? Demodulates General Tech 2 09-18-2015 12:14 PM
JLT III CAI cleaning, do I re-oil? kevsgt GT S197 General Discussion 1 09-09-2015 07:20 AM
