Oil and Oil Related Topics A place to post your oil related questions and comments
Oil Analysis report
Old 08-17-2009, 08:31 PM
65rangoon
65rangoon's Avatar
oh , where is your report from?
65rangoon is offline
Old 08-17-2009, 10:23 PM
ShadyNinja
ShadyNinja's Avatar
I have been using
Oil Analyzers Inc. http://www.oaitesting.com/
did you see the zinc levels of our used oil?
there are still some oils on the market that have the pressure additives that the flat tappet cams need.
no need to add any product to your oil.
ShadyNinja is offline
Old 11-19-2009, 10:55 AM
ShadyNinja
ShadyNinja's Avatar
Engine builder said motor looked like new when he took it apart to freshen it up
Old 11-21-2009, 12:39 PM
65rangoon
65rangoon's Avatar
good deal. ill finally be changing the oil in my DD at least next week.
i ended up not doin the traveling i thought i would be doing and didnt want to change it just to change it.
hopefully after i change it at thanksgiving ill have the report back shortly there after and we can see what the blackstone labs report looks like compared to yours for readability.
not sure if ill be doing the mustang at this time though. hell i think that oil only has 1k miles on it. granted ive been going to change it extra frequently since its sat so much over the years (only has 30k miles on original motor/trans and its a 65)
ill prolly change it next spring when i get it out to drive rather then changing it and lettin it sit all winter
Old 11-22-2009, 12:22 AM
ShadyNinja
ShadyNinja's Avatar
if you want to know how much life the oil had left in it, you need them to do the TBN , total base number , that is a extra 10 bucks I believe , but if you were trying to see how long to run your oil , that is a important test.
the lab I use does the tbn for free on all samples, so that makes the oai ones cheaper.
Old 11-22-2009, 06:25 AM
65rangoon
65rangoon's Avatar
good to know.
maybe ill order up some of the OAI lab bottles then.
main reason i was going to do BL was they dont charge you until you send it in.
OAI charges you when you order the bottle
Old 11-22-2009, 11:54 AM
ShadyNinja
ShadyNinja's Avatar
good to know.
yep the testing is prepaid,
and depending on which one you choose the shipping / postage is already paid too.
(I use the ups one)
Old 06-10-2010, 09:29 AM
ShadyNinja
ShadyNinja's Avatar
here is a report I got back today
Old 06-24-2010, 11:21 PM
Unleashedbeast
Unleashedbeast's Avatar
The higher Zinc and Phos in the racing oil will protect those flat tappets for sure. That's also what I love about Amsoil's street oils, they retain higher levels of both to minimize engine wear (versus comparable weights in competitive brands).
Unleashedbeast is offline
Old 06-27-2010, 12:09 PM
ShadyNinja
ShadyNinja's Avatar
I am going to see if I can get one of the other teams we race with to submit one of these.
Quick Reply: Oil Analysis report
