Go Back   MustangForums.com > Ford Mustang Tech > Oil and Oil Related Topics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-01-2009, 09:43 PM   #1
geryogery
2002 Ford Mustang
Vehicle: 2002, ford, mustang
Default How Much Oil Do You Use???
I just changed my oil and replaced it with 5 bottles. I noticed that the level went a little over the middle of the min and max points.
Is it recommended to fill it to the max? How much oil do all of you use?
__________________
geryogery is offline   Reply With Quote
Old 08-01-2009, 11:30 PM   #2
SilverNGrey4.6s
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
6qt's on both
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf.
http://Centraltexasstangs.com
SilverNGrey4.6s is online now   Reply With Quote
Old 08-02-2009, 01:53 AM   #3
Mustang Boy
Cool
was that level before or after you started the vehicle because if you put the oil filter on empty the filter has to prime and fill up with oil before you will get the correct reading on the dipstick
and you should use six quarts
Mustang Boy is offline   Reply With Quote
Old 08-02-2009, 10:15 AM   #4
geryogery
2002 Ford Mustang
Oh yeah, the engine was started and the filter primed before the reading.
Thanks.
__________________
Old 10-10-2009, 11:19 AM   #5
Rubrignitz
2007 Ford Mustang
Rubrignitz's Avatar
Vehicle: 2007 Mustang GT Coupe
I put 6 qts of amsoil sig series 0w-30 in when I change it and after 10k miles the dipsitck is exactly between the hi-low levels. maybe 1/2 qt??
__________________
2007 Alloy GT Coupe/MGW shifter/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555/Autometer DPSS shift light and gauges. Suspension: Steeda Comp Springs/GT500 Front CA's with Steeda X5 balljoints/Steeda bumpsteer kit/Tokico D-Specs/BMR adj upper & lower LCAs+relocation brackets/Hotchkis 3/4way adj swaybars/UMI Performance panhard.
Rubrignitz is online now   Reply With Quote
Old 10-14-2009, 12:51 AM   #6
Grabber
2003 Ford Mustang
Grabber's Avatar
Vehicle: 2003 Cobra
I use 6qt's. Always have, Always will.
__________________
2003 10th Anni Torch Red Cobra 462 RWHP 486 RWTQ SAE
Fluidyne Heat Exchanger
H&R Springs
K&N FIPK
Mac O/R Prochamber and Borla Stinger C/B
BF 2.76 Pulley
LDC Chicago HCM
Many more mods
Grabber is online now   Reply With Quote
Old 10-14-2009, 01:05 AM   #7
Fink
1999 Ford Mustang
Fink's Avatar
Vehicle: 1999 Ford Mustang
5.4 liters.
__________________
Mods:
MAC LT's & O/R H, ROUSH Side Exhaust, GT Rear Sway, SCT X3, Auburn LSD w/ 3.27's
Waiting:
Cobra Brake Kit Front and Rear, KYB GR-2 Shocks/Struts (waiting on C/C plates)
Quote:
Originally Posted by brian1570 View Post
now RS is gonna come in here and start sh!tting on his keyboard again.
Fink is offline   Reply With Quote
Old 10-14-2009, 03:39 PM   #8
mustang51js
Vehicle: 2002 mustang gt
my 97 gt took 8qts and my 02 takes between 6-7
__________________
02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
mustang51js is offline   Reply With Quote
00, 2002, 50, air, dipstick, edge, filter, ford, gt, jlt, mustang, oil, post, put, reading
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
