Go Back   MustangForums.com > Ford Mustang Tech > Oil and Oil Related Topics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-22-2009, 09:48 PM   #1
sandman383
Vehicle: 2001 Mustang Coupe
Arrow 2001 V6 Reg or Synthetic Oil results?
Hello
I have a 2001 Mustang with a 3.8 V6 Automatic.
I just bought it and I imagine that the only oil that has been in there has been regular oil.
My question is this, what results have any of you out there had in using a Synthetic Oil in the 99 - 04 Mustangs like mine? Good - Bad - Leaking?
Thanks for all your help.
sandman383 is offline   Reply With Quote
Old 09-23-2009, 09:16 PM   #2
SilverNGrey4.6s
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
you'll be fine
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf.
http://Centraltexasstangs.com
SilverNGrey4.6s is offline   Reply With Quote
Old 09-28-2009, 01:55 AM   #3
2000Stanglover
2000Stanglover's Avatar
Vehicle: 2000, Ford, Mustang
Just keep useing reg. i use castrol gtx in mine.
__________________
2000 3.8 v6 mustang
CAI
single flowmaster 40 for exhaust.
thats is right now but more on the way.
Quote:
Original: Nuke
I didn't buy a Stang for its reliability. I bought it for the wood I get when I drive it.
2000Stanglover is offline   Reply With Quote
Old 09-29-2009, 07:19 PM   #4
CJ043Pt9Pony
CJ043Pt9Pony's Avatar
Vehicle: 2004 Ford Mustang
Ok, i started using Mobil 1 5w20 Synthetic on my wifes stang when she had 40k on it, i said f' the Mobil 1 b/c Valvoline Full Syn is better. Pretty much anytime, once you get a good amount of miles on your stang, like even if its 30-40k. Like mine, once i switched from Conventional oil to Synthetic you'll usually started to leak a little bit. Just b/c the oil is thinner then conventional oil. I just used Bars Engine Stop leak on my '04 3.9L, havent checked to see if it has stopped leaking im sure it has. B/c ive used it on some of my s10's since i switched to high mileage syn blend, and completely stopped my pan leaks. My '04 stang wasnt really leaking that bad. BARS Engine stop leak works Great, its made NOT to clog up passages and the engine. Havent had any problems! GOOD LUCK!
VALVOLINE 5W20 FULL SYN
K&N OIL FILTER
CJ043Pt9Pony is offline   Reply With Quote
Old 10-05-2009, 05:07 PM   #5
sandman383
Arrow Thanks you
Hey thank you both for the reply!
I mentioned all this to my dad and he strongly suggested that I keep using regular oil every 3000 miles. He also mentioned that the synthetic is very pricy!
Again thank you!
Old 10-05-2009, 06:46 PM   #6
SilverNGrey4.6s
Quote:
Im not sure what you call pricey, but you can get a 5qt jug of pennzoil platinum synthetic oil for $20 at walmart.
__________________
JLT Cold air intake
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
H&R sport springs
2000, 2001, 2009, 38, 99, cylinder, ford, forums, gt, mustang, oil, put, recommended, synthetic, type, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
