Go Back   MustangForums.com > Ford Mustang Tech > Oil and Oil Related Topics
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-29-2009, 10:59 PM   #1
nobull805
Vehicle: 1997 mustang gt coupe 4.6
Default oil in radiator resivior...
does anyone know what it means to have oil in with antifreeze..?need help!
nobull805 is offline   Reply With Quote
Old 10-31-2009, 10:11 PM   #2
SilverNGrey4.6s
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
blown head gasket??
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf.
http://Centraltexasstangs.com
SilverNGrey4.6s is offline   Reply With Quote
Old 11-01-2009, 04:57 PM   #3
nobull805
theres no white smoke or loss of power and the oil in pan is fine car also runs fine
Old 11-01-2009, 10:10 PM   #4
mike castaldo
Vehicle: ford 2006 mustang gt
Quote:
its a head gasket
mike castaldo is offline   Reply With Quote
Old 11-02-2009, 08:28 PM   #5
nobull805
so is it just a matter of time for water to get in oil or what.thanks for replying
Old 11-02-2009, 08:47 PM   #6
jwog666
2003 Ford Mustang
jwog666's Avatar
Vehicle: 03 mustang gt
sometimes that stop leak crap can look like oil floating in the resevoir. but before condemning the head gasket a cooling system pressure test should be performed.
__________________
Granatelli shark plenum, 75mm tb, steeda udp's, pypes catted x pipe, pypes violator catback, steeda tri-ax, 3.73's, spec stage 1 clutch, diablosport tune, tail light sequencers, mach 1 grill delete & chin spoiler
jwog666 is offline   Reply With Quote
Old 11-02-2009, 09:19 PM   #7
garcia66
Vehicle: 1966 Mustang
its probably a head gasket. or your head is cracked
Have it pressure tested or you can do it yourself if you have a radiator pressure tester. They cost around 50.00-200.00 and you put it on your radiator (where your cap goes) then you pump it too pressurize the cooling system and you wont maintain pressure if you have a blown head gasket.
garcia66 is offline   Reply With Quote
1997, 46, ford, gasket, head, motor, mustang, oil, rad, radiator
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
