Oil and Oil Related Topics A place to post your oil related questions and comments
Royal Purple Oil Experience - 2005 Mustang GT
Old 12-03-2009, 03:20 PM
2k05gt
2k05gt's Avatar
Default Royal Purple Oil Experience - 2005 Mustang GT
I don't want to start an OIL's War.. But I want to express my Recent Experience with Royal Purple 5w20 in my 2005 Mustang GT. I ran Royal Purple since I bought the car and it had it's first Oil Change (July 2005) 70,000 miles lator and I replaced the Stock Cams with COMP 127200 NSR Cams. Anyway, I did not look at the cams until months lator when I noticed they looked new, confused I asked a friend to loan me his cams from his 2007 Mustang GT with 40,000 miles using Mobil 1 5w20.
Right off the bat I noticed the scaring and coloration. So I decided to Document the findings. Could the Royal Purple Marketing be True?
This Image shows Both Cams with Descriptions.
Image 4 & 5 show No wear from the edge of the Lobe to the center of the lobe on Royal Purple 5w20
Measure the Edge because I need a surface that has not been touched by the follower (Baseline)
Measure the Center and shows no wear
Image 4 & 5 Show wearing on the Cam Lobe from the follower on the Mobil 1 5w20 Oil
sure 100th of a MM is minor but the Royal Purple Cam has almost twice the Milage...
Again Measure the Edge for a baseline
Then the Center and there was some wear.
So I had to make sure my test vehicle was not a fluke so i borrowed another set of cams from a 2006 Mustang GT (image #3)
with 36,000 miles who always used Mobil 1 as well. Again the Cams look simular, (Top cam from 2006, Middle Cam from 2007
and the Bottom Cam from the 2005)
You can make your own conclusions but from this test I would have to say that Royal Purple's Claims about Less friction, less wear is not a gimick...
Amsoil and Royal Purple are very simular in that they are 100% Synthetic (No Mineral Oil Base Stock) like Mobil 1 and they both add ZDDP and additive that cleanes the engine and reduces wear. Royal Purple adds a small amount of a Moly simular to graphite this may be what created the reduced friction.
Attached Thumbnails Royal Purple Oil Experience - 2005 Mustang GT-m1-center.jpg   Royal Purple Oil Experience - 2005 Mustang GT-m1-edge.jpg   Royal Purple Oil Experience - 2005 Mustang GT-taleof3cams.jpg   Royal Purple Oil Experience - 2005 Mustang GT-rp-center.jpg   Royal Purple Oil Experience - 2005 Mustang GT-rp-edge.jpg
2k05gt is offline
Old 12-03-2009, 08:07 PM
Grabber
Grabber's Avatar
Goes to show RP is not bad, and this proves the point very well.
I personally still love RP, even though I just changed to Amsoil to give it a shot.
However, I also hate Dealers that try to make money on putting down other oils, and try to convince members a certain oil is bad, and xxx oil is better.
All in all, I am very happy with these results. Do you have any pics of your oil pan? If not, disregard.
-Chris
Grabber is offline
Old 12-03-2009, 09:59 PM
DreamerGT
DreamerGT's Avatar
Wow Im really impress by that. thanks for posting up
DreamerGT is offline
Old 12-04-2009, 06:27 AM
2k05gt
2k05gt's Avatar
-Chris
No Oil pan Pictures, I only replaced the stock Cams with Comp NSR 127200
I am getting a UOA (Used Oil Analysis) Done this month, I will report the results.
+1 on the Comment about One Oil Company Bashing another, Thats One Reason I will not Use Amsoil and because I do not like MLM business model. If the Oil is so good whay can't I buy it at the auto parts store? JMO Other than that Amsoil is a Good oil, I just can't get myself to do a 24,000 mile oil change... 5000 is the max I will do for any oil.
Also I am not bashing any oil, I am only pointing out my results with Royal Purple. Yes it's a buck more than M1 but from these results it's worth it IMO.
2k05gt is offline
Old 12-05-2009, 08:01 AM
QbonStang95GT
QbonStang95GT's Avatar
wow thanks for posting that i use RP to so im glad to know that extra dollar is not jus for the name
QbonStang95GT is offline
Old 12-07-2009, 10:07 PM
ShadyNinja
ShadyNinja's Avatar
AWESOME THREAD
Thank you for the photos!
Cant wait to see the oai
ShadyNinja is offline
Old 12-20-2009, 03:17 PM
2k05gt
2k05gt's Avatar
Ok here is the UOA, I have used Race Fuel in the past month so take that into account...
2k05gt is offline
Old 12-20-2009, 04:38 PM
BruceH
BruceH's Avatar
BruceH is offline
Old 12-20-2009, 06:42 PM
StriderTacticaL
StriderTacticaL's Avatar
Nice thread. I've been using M1 since I bought my car but recently just switched to RP and then had some doubts. But now I think I am going to stick to it.
StriderTacticaL is offline
Old 12-20-2009, 10:44 PM
2k05gt
2k05gt's Avatar
Originally Posted by BruceH
Thanks for posting that up. Any oil consumption?
None at all. I check it each week and come time to change my oil I almost fill up all the 6 qt bottles that I take to the recycling center for disposal.
StriderTacticaL,
Why some doubts? Royal Purple is a 12,000 miles Change interval Oil, you can see that by the TBN Number, as the oil breaks down the TBN goes down and the effectivness of oil deminishes. a TBN of 2 would be time to change the oil, I have 5000 miles and the TBN is at the top of the scale 0-5 so the oil have a lot of life left. If I wanted to save some money I would buy one qt and a new filter (always change the filter no later than 6000 miles) I use Ford Racing CM-6731-FL820 Filters, but the K&N and Mobil 1 Filters are the same quality filter and they are made by Champian Labs and the guys are identical, so what ever filter you can get cheaper (M1 or K&N) they are the same.
In the UOA sheet, you can see the Silicone level being low, that means the Air Filter is working well, and the Magnesium is an additive in the Oil the same with the Moly and Zinc (ZDDP) is an additive to reduce wear.
You will like RP it's good stuff.
2k05gt is offline
Quick Reply: Royal Purple Oil Experience - 2005 Mustang GT
