Oil and Oil Related Topics A place to post your oil related questions and comments
Oil Chage?
Old 03-20-2010, 10:51 AM
Bulldog339
Bulldog339's Avatar
Default Oil Chage?
Just bought a '02 Mustang 6 cylinder.
It has 86000 miles.
Should i use the recommended 5-20, or would their be something better?
Bulldog339 is offline
Old 03-20-2010, 11:57 AM
DreamerGT
DreamerGT's Avatar
yeah 5w 20 will sever you well, just stick with that.
DreamerGT is offline
Old 03-21-2010, 04:53 PM
nascrchi
nascrchi's Avatar
How do we know when to put in a heavier weight? when we have to put oil in the motor between oil changes?
nascrchi is offline
Old 03-21-2010, 09:05 PM
65rangoon
65rangoon's Avatar
iirc the oils will be the same weight when at operating temp. they are just a different weight/viscosity when cold.
65rangoon is offline
Old 05-20-2010, 03:52 PM
ndhoffma
ndhoffma's Avatar
It has 86000 miles.
Heavier isn't necessarily better.. for 'better' make sure you go for a higher quality oil & filter. As long as you have good oil & a good filter, the engine will be plenty well protected with how advanced oils are today. I saw a few other threads on oil & filters with some good advice on that stuff
ndhoffma is offline
Old 06-24-2010, 11:47 PM
Unleashedbeast
Unleashedbeast's Avatar
IIRC, your engine is spec'd for a 5W-30 oil, but reguardless...Amsoil spec's the car to use either 5W-30 or 5W-20. I doubt you would notice the difference between the two weights unless your V6 made a little more valvetrain noise with the lighter oil.
Engine Oil
Grade 1......API*
Signature Series 0W-30 100% Synthetic Motor Oil (SSOQT)
SAE 5W-30 Synthetic Motor Oil (ASLQT)
100% Synthetic 0W-20 Motor Oil (ASMQT)
XL 5W-20 Synthetic Motor Oil (XLMQT)
All TEMPS......5W-30, 5W-20 [1]
Unleashedbeast is offline
wraith777
09-28-2015 10:49 AM
Shadow7874
09-24-2015 09:06 PM
belam
09-23-2015 11:29 PM
Demodulates
09-18-2015 11:14 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Oil Chage?
