Synthetic oil
yes and yes
been using it since about 1996 or so
i can tell you right now that the color of the oil at 5000 miles is like the color of conventional oil at 3000 miles..... syn is still goldish at 3k
so yeah it works
worth the money ??? not much diff in price really
go to walmart and get the 5 qt jug for $24, cant beat that except
when o'reillys has the special , 5 qts + a mobil 1 filter for $17.99
so yeah it works
If you plan to change your oil at 3-5K miles, synthetics aren't really worth the money. If you take advantage of the extended drain intervals from 7500 miles up to 25000 miles (Amsoil SSO) then yes, they make oil changes much cheaper in the long run.
