Oil and Oil Related Topics A place to post your oil related questions and comments
Oil weights and change intervals.
Old 08-11-2010, 10:21 AM
uberstang1
Chupacabra
uberstang1's Avatar
Default Oil weights and change intervals.
Well im still living in the past I guess after doing some reasearch. I have a stock 97 4v procharged and im running 10w30 valvoline synpower in it. And also a 02 f150 with the 4.6 and running the same in that. The mustang only gets driving 3-4k miles a year but i continue to change the oil and filter every 3 months. Same with the truck, is this pure overkill. Also Id like to switch to a better base stock oil for the mustang. As far as wight goes I live in PA and just run the 10w30 all year (mustang only gets started a few times over winter) I know the mustang calls for 5w30 and the f150 is calling for 5w20 just seems kinda thin to run. the truck has 90k and the mustang engine has about 75k what do you all think.
uberstang1 is offline
Old 08-11-2010, 12:42 PM
DreamerGT
DreamerGT's Avatar
My stang get around the same miles a year as yours, and I change it once a year. Yes changing it every 3 months is a over kill. Synpower is a really oil just stick with that. As far as weight you can keep using 10w-30 if you want, but 5w-20 wont blow your motor up, when the oil gets hot its not that much thinner than what your using now.
edit: Just let your car sit no need to start it up in the winter, that can be bad for the oil.
DreamerGT is offline
Old 08-11-2010, 03:21 PM
lizzyfan
Underboss
lizzyfan's Avatar
Uber, see my other threads
5w30 Motorcraft oil with your miles/OCI can't beat the quality/price
lizzyfan is offline
Old 08-11-2010, 04:11 PM
uberstang1
Chupacabra
uberstang1's Avatar
Hmm so i could get away with 5w30 even with higher miles I have some unknown fear of 5w oil. I know my f150 says 5w20 and im def scared of that, u think 5w30 would be food for the 4.6 in my f150 even with high miles?
Old 08-11-2010, 04:28 PM
lizzyfan
Underboss
lizzyfan's Avatar
it'll be fine
lizzyfan is offline
Old 08-11-2010, 05:13 PM
ShadyNinja
ShadyNinja's Avatar
I have 160,000 on my 2000 mustang I run 0w30
don't fear any number that is before the W its the number after the W that you need to pay attention to.
ShadyNinja is offline
Old 08-11-2010, 05:43 PM
LS WHAT
LS WHAT's Avatar
the w means winter not weight
LS WHAT is offline
Old 08-11-2010, 06:31 PM
Unleashedbeast
Unleashedbeast's Avatar
and refers to it's cold pour ability, or how well it flows at sub zero temperatures.
I also run 0W-30...do not fear the 0 or 5W oils.
Unleashedbeast is offline
mtgldr
02-03-2024 09:00 PM
MusicCity615
09-12-2015 07:05 AM
kevsgt
09-09-2015 06:20 AM
09-08-2015 11:50 AM
Quick Reply: Oil weights and change intervals.
