oil filter question
oil filter question
Hi I just picked up my stock 05 gt and I am going to do my first oil change. Can you use a regular motorcraft filter with full synthetic mobile one oil or do you need to use that expensive mobile 1 filter too?
bang for the buck, you can't beat the MC filter running it 5,000 miles or less. Unless you plan to run extended drain intervals I wouldn't look beyond it.
Also, if you are going to run a standard ~5,000 oil change interval, take our advice and steer clear of Mobil 1 Syn 5W-20 API SM motor oil (I would buy their extended performance before their regular syn). IMO, you could have better oil using Pennzoil Platinum or Ultra. You may even look to using Motorcraft Syn blend 5W-20, and it would be a big savings over Mobil 1.
https://mustangforums.com/forum/oil-...ustang-gt.html
and educate yourself about engine lubricant formulation at this link
http://www.driven2modify.com/showthread.php?t=25162
She immediately noticed an increase in heat, less comfort, and a lot less efficiency, and OMG at the increase in dis-satisfaction noise.
I was told to go back to 100% full synthetic lube or I won't be taking her for test drives any longer.
1. increased oil change intervals (run oil less miles)
2. increased coolant temperatures (documented many times and many different applications.
3. increased mechanical noises (not everyone has reported this)
*Esters that are formulated into a full synthetic actually allows engine oil to adhere to metal surfaces like a magnet. This eliminates cold starts and mechanical noises at initial start up.*
Most people have no clue the true benefits of using a superior engine lubricant. I do, and nothing else will be in any engine I have.
