Increased oil weight, and MPG improved, Possible? - Page 2 - MustangForums.com
Oil and Oil Related Topics A place to post your oil related questions and comments
Old 09-05-2010, 09:05 PM   #11
JIM5.0
JIM5.0's Avatar
Just so I can be better educated, can you describe in depth what this shearing resistance is you are describing? I am not familiar with the term and how a fluid can resist shearing forces. Forgive me, when I think of shearing forces, I think of solids (the ultimate form of shearing force resistance, at least until the material fails).
JIM5.0 is offline   Reply With Quote
Old 09-06-2010, 07:25 AM   #12
Norm Peterson
Norm Peterson's Avatar
I'd start here. Not sure what happens on a molecular level, but I doubt it to be good.
Norm
Norm Peterson is offline   Reply With Quote
Old 09-06-2010, 10:51 AM   #13
Unleashedbeast
Unleashedbeast's Avatar
Thanks Norm.
To put it in easy terms Jim5.0,
Let's say a lubricant is formulated to be a 30W at 100*C, but as the additive pack and base stock break down after many miles of use the oil thins to a 20W oil. This is called shearing.
100% true synthetics resist shearing much better than a petroleum (group III) based oil due to the superior PAO group IV base stock and additive pack. Just another reason why you have much longer drain intervals of a true synthetic.
Unleashedbeast is offline   Reply With Quote
Old 09-06-2010, 01:52 PM   #14
DreamerGT
Remember all oils are formulated differently. A thin 30-weight is more likely to drop to a 20-weight with just a little bit of shearing. A thick 30-weight will have a longer way to go before it thins, if at all.
DreamerGT is offline   Reply With Quote
Old 09-06-2010, 08:02 PM   #15
Unleashedbeast
Very true Dreamer, good addition of information. Seems I always forget the detail while typing at work.
Old 12-19-2010, 06:09 AM   #16
everett
K found it. Great write up I will be switching back to 0w30. If you weren't aware if you register with amsoil they will recognize you as a preferred customer and sell everything they supply at wholesale. But from the wealth of knowledge you possess I will assume you are already a dealer
everett is offline   Reply With Quote
Old 03-03-2011, 11:32 AM   #17
EVILHORSE
EVILHORSE's Avatar
This was a great read unleashedbeast , but will i see the same results on a 4.0L v6 as you do your V8's ???????
EVILHORSE is offline   Reply With Quote
Old 03-03-2011, 01:24 PM   #18
Unleashedbeast
Quote:
of course you will, the same principals apply. Try it, and see for yourself.
Old 10-22-2012, 04:52 AM   #19
keisha008
keisha008's Avatar
I notice this thread is almost 2-years old, but since it discussed oil related issues, I decided to still add my post in this thread. Just recently I learned that Ford company is working on improving gas mileage requirements in its automobile. With regard to this, I do not even have to buy a hybrid to get something fuel efficient. I used a site I came across to help me find a Ford in Brooklyn. You can check out this site here for more info: Courtesy cars Brooklyn.
keisha008 is offline   Reply With Quote
Old 11-18-2012, 09:57 PM   #20
ticopowell
Great info! thanks for the work, but a few questions for you...
Am I correct in assuming that the same concept applies to my 5.0 engine? and also I assume that any full synthetic, Amsoil, Royal purple, etc.. will have the same effect on performance?
Thanks!
ticopowell is offline   Reply With Quote
S197 Parts baddog671 Parts For Sale 20 07-26-2016 01:20 PM
Kenny Brown AGS 4.0 panhard bar relocation flash_xx S197 Handling Section 14 10-16-2015 07:23 AM
So who wins uedlose The Racers Bench 4 10-01-2015 08:31 PM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 10:13 AM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 10:49 AM
0w, 0w30, 2007, 30, 3v, 46l, 50, amsoil, ford, mpg, oil, speed, sso, town, v8, weight
