Oil and Oil Related Topics A place to post your oil related questions and comments
Proper amount of oil 2010 4.0 liter mustang
Old 06-17-2011, 09:08 PM
DrivingTopDown
DrivingTopDown's Avatar
Default Proper amount of oil 2010 4.0 liter mustang
I have had my car overfilled by dealers in the past... i.e. past the top hole in the dipstick
As I understand it... if I drain my oil and replace the oil filter I should then put five quarts of oil in my engine. This will give me an oil level somewhere between the lower hole in my dipstick and the upper hole.
The last dealer I went to put more than five quarts and the oil level sits at the top hole (actually a tiny bit past). The owners manual states BETWEEN the holes is fine. I have had a few oil changes and most of them leave the level at the top hole or various degrees above.
I would think that the dealer would just put in five quarts and leave it at that.
Any thoughts?
DrivingTopDown is offline
Old 06-20-2011, 10:34 AM
lizzyfan
Underboss
lizzyfan's Avatar
Should be 5 qts
lizzyfan is offline
Old 06-21-2011, 12:23 PM
Alec
Alec's Avatar
Originally Posted by lizzyfan
Should be 5 qts
Yep that's what I use and is recommended. 99% sure the 4.6s use 6
Alec is offline
Old 06-21-2011, 08:06 PM
DrivingTopDown
Thanks... If anyone has any definitive quotes from Ford I would appreciate it
Old 06-26-2011, 03:07 PM
Unleashedbeast
Unleashedbeast's Avatar
Should be 5 qts
You are correct. The factory fill is exactly 5 quarts with a filter change.
Unleashedbeast is offline
Old 07-10-2011, 07:53 PM
05SatinSilverGT
05SatinSilverGT's Avatar
As it's been said, 5 quarts for the 4.0, 6 for the 4.6.
05SatinSilverGT is offline
Old 07-10-2011, 08:07 PM
kzonts
kzonts's Avatar
Owners manual says "5" qts.
kzonts is offline
MEISTERSNFB
03-31-2020 07:50 AM
Barcafut13
08-13-2015 08:05 AM
StangMuscle
08-12-2015 07:27 AM
daytooday
08-11-2015 09:22 AM
Barcafut13
08-10-2015 07:44 PM
Quick Reply: Proper amount of oil 2010 4.0 liter mustang
