What transmisison fluid should i use?
First off want to say hi and thanks for all the great info on this forum.
I own a 2001 Mustang GT with a 5 speed manual transmision. I'm wanting to change my trans fluid and was wondering what type i should use/is recommended to use. The car is a daily drive with a round trup of 68 miles and 20/80 city and highway on the drive.
Thanks,
David
Thanks,
David
Was thinking this would be it, but want to make sure before I buy it.
https://www.amsoil.com/storefront/mtf.aspx
Synchromesh will work for your application, but it's not the best choice. This is what will make your T-3650 shift like butter.
Amsoil Synthetic ATF
Here is Amsoil's look up it Shows every product they make for your car, and How much it holds.
Looks like its ATF for your car
https://www.amsoil.com/mygarage/vehi...FORD+MUSTANG+R
Nothing wrong with Amsoil, but I'd be inclined to go the local autoparts stores and pick up 3 quarts of Valvoline's Maxlife Dex/Merc ATF... Synthetic blend, and $4 dollars/quart. In my limited experience, manual transmission are not the best place for extended drains...
Most owners use the fluid in their transmission for at least 50,000 miles or greater. What fluid would you prefer for 50,000 miles or more?
There is more to using a true synthetic in a transmission than simply extended drains. Shift quality using a cheap conventional compared to a true synthetic can't even be compared. It's the difference in night and day. Not to mention, when your car is cold...and you start it for the first time on a cold day, it shifts much better than a cheap conventional will, since a true synthetic thickens much less as it cools.
Don't get me wrong, I use synthetic oils and fluids in certain applications in the car, the truck, and the ATV just not in an unfiltered, low volume manual tranny...
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
