Oil and Oil Related Topics A place to post your oil related questions and comments
What type of Oil does everyone use?
Old 04-26-2012, 10:22 AM
  #21
Unleashedbeast
Unleashedbeast's Avatar
It's a cheap group II base stock lubricant that's marketed to be more than it actually is. Read this entire thread on BITOG about it. For what you are actually buying, it's overpriced too.
Swepco - BITOG
Unleashedbeast is offline
Old 11-25-2012, 08:54 PM
  #22
T.Richardson
T.Richardson's Avatar
This thread has been pretty informative. I been using Castrol.. might switch over to Amsoil.
T.Richardson is offline
Old 12-24-2012, 11:12 PM
  #23
J95SNAKE
J95SNAKE's Avatar
Amsoil looks like a good choice. I'm thinking about switching to it on my first change.
J95SNAKE is offline
Old 12-29-2012, 10:49 PM
  #24
Nyke
Nyke's Avatar
AMSOIL is a great choice.
The biggest difference in synthetic oil and conventional oil. Imagine a empty closed room, filled with different size *****, from marbles to those big huge exercising ***** that people film throwing and kicking into other peoples faces. Each of these ***** you are imagining represents the size of a molecule in your oil. Conventional oil has different size ***** (molecules) big and small. Each time your engine is operating these big ones chew up your engine and the small ones squeeze by. In synthetic oil all the ***** (molecules) are the same size, and they are small, comparable to the baseballs in the room when put up against the big exercise *****.
As to why many people have leaks when using synthetic oil is because they used to use conventional oil and went to synthetic. So now the path ways the bigger ***** (molecules) left behind from using the conventional oil, the smaller ***** (molecules) from the synthetic oil just walk right though the bigger path. Basically the seal is too worn for the use of synthetic oil so it burns and leaks.
In Automotive we only use Grades 3, 4 and 5.
Grade 3 is your basic conventional (dino juice) oil. Ex. Pennzoil, Quaker State, Wal-Mart (lol?) Unless the bottle says synthetic.
Grade 4 is kind of synthetic oil however it is not truly synthetic. Grade 4 oil is conventional oil that is derived of dino juice and cleaned extremely well and sent through a filtering process which sorts the molecules into the same size. (think of mixed nuts being sorted. Cashews and walnuts are different in shape, they just put them together) Moble 1 is a Grade 4 oil, look on the back of the bottle and it says GL-4. Yet on the front it says fully synthetic, which is a LIE! It is technically a highly refined synthetic blend.
Grade 5 is 100% PURE Synthetic Oil. Everything that goes into making the oil, the additives, EVERYTHING is 100% Pure synthetic. It does not go through a filter to break down bigger molecules, everything is already formulated form the ground up to be the same size. This is the best out there.
I only know of 3 companies that make Grade 5 (GL-5) Oil. They are Royal Purple, Amsoil, and Redline.
Granted there is much more information that goes into this but this should give you a general understanding of the types of oils there are.
If you have any questions or if something is not stated clearly let me know. Il will answer/correct it.
By the way... I am a Lexus Certified Diagnostic Tech (The shops brain) for over 6 years. I have to know this stuff!
Nyke is offline
Old 02-18-2013, 05:54 PM
  #25
harleyguy*
harleyguy*'s Avatar
all the info was educational,but the one topic i very seldom see is what about the oil in the 5speed tranny,and rear end.should they be changed?or just topped off .at 45,000mi.? and what kind of oil should be used? thanks for your answers.
harley guy
harleyguy* is offline
Old 02-27-2013, 01:09 AM
  #26
Whitestang41791
Whitestang41791's Avatar
after using ford motorcraft blend for 45,000 miles, can i switch over to a full synthetic oil?
Whitestang41791 is offline
Old 02-27-2013, 03:21 AM
  #27
audioAl
audioAl's Avatar
Default Valvoline?
Sure you can switch, I've used Castrol Edge & Royal Purple. The purple I still use in
my 98 Mercury Villager GS van. I go 6,000 miles and change. My new 3.7 will get the
Motorcraft because I get free oil changes for life at my Dealer. Oop's, I went to NAPA
parts and got a GF-5 rated "Full Synthetic" NAPA oil made by Valvoline so say's the
counter man. Used a NAPA "Gold" made by Wix filter.
audioAl is offline
Old 03-21-2013, 12:02 AM
  #28
SXGT
SXGT's Avatar
for about 8 years I used Valvoline full synthetic. For the last 5 I have been using Mobil1 full synthetic.
next change I am going to try Amsoil or Royal Purple.
also a day or two before my next change I think I might dump some seafoam into the oil and let its soak in for 30 miles and then drain it and the oil all out.
SXGT is offline
Old 03-21-2013, 07:35 PM
  #29
TomKat
TomKat's Avatar
ford synthetic blend 5w-30 or Pennzoil 5w-30 conventional.
TomKat is offline
Old 04-30-2013, 03:59 AM
  #30
Conundrum
Conundrum's Avatar
OK so which of the 3 would you recommend?
Conundrum is offline
Quick Reply: What type of Oil does everyone use?
