Lucas Oil Stabilizer Fail!!! DO NOT BUY!!! - MustangForums.com
Oil and Oil Related Topics A place to post your oil related questions and comments
Old 02-13-2012, 01:23 AM   #1
ckyfreak2010
Default Lucas Oil Stabilizer Fail!!! DO NOT BUY!!!
ckyfreak2010 is offline   Reply With Quote
Old 02-13-2012, 08:22 PM   #2
uberstang1
Chupacabra
uberstang1's Avatar
Im not a fan of it personally but alot of people use it without issue, this test is totally rediculous the reason it foams in that display is because there is no way to vent pressure build up like a motor can do in operation............especially spinnig it in such a small dispacement case with a power drill.
uberstang1 is offline   Reply With Quote
Old 02-14-2012, 05:58 AM   #3
Lem-06
Lem-06's Avatar
how about we all agree that this little display doesnt prove anything.
Coming this spring, full sized displays of running motors with Lucas Oil Stabilizer!
lol
Lem-06 is offline   Reply With Quote
Old 02-14-2012, 08:27 AM   #4
JRC702
JRC702's Avatar
I also agree the display means nothing.
Not a fan of any Lucas product. Use a quality oil that meets ILSAC GF-5 and change it often to prevent sludging and you don't need to worry about crap like oil stabilizers.
JRC702 is offline   Reply With Quote
Old 02-15-2012, 08:54 PM   #5
lizzyfan
Underboss
lizzyfan's Avatar
You got to admit it's fun to spin it
Not sold on it tho, think it's a ploy
lizzyfan is offline   Reply With Quote
Old 02-28-2012, 02:08 AM   #6
Unleashedbeast
Unleashedbeast's Avatar
It's the equivalent to a heavy 60 grade engine lubricant with zero additives.
Using this, you have effectively diluted critical anti-wear engine lubricant additives with one quart of oil stabilizer that does nothing more than make the lubricant more viscous.
If you need a more viscous oil to solve eternal engines issues that normally are a per-cursor to an engine rebuild, just buy the heaviest 20W-50 lubricant you can find and use it. You would have accomplished the same thing.
Unleashedbeast is offline   Reply With Quote
Old 03-02-2012, 08:52 AM   #7
phoenixfriend84
phoenixfriend84's Avatar
I've seen many such displays as this that show Lucas foaming. Some quite larger than those at the store. There's a website called Bob is the oil Guy that has lots if info on it. The idea that it doesn't prove anything is wrong. As the plain oil was spun the same rpm with the same conditions as the Lucas and no foam.
phoenixfriend84 is offline   Reply With Quote
Old 03-29-2013, 03:57 PM   #8
The02GT
Yep, the stuff traps air, dont want air between my crank and bearings, lol
The02GT is offline   Reply With Quote
First Impression 2015Ecoboost New Member Area 3 09-17-2015 02:48 PM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 01:08 PM
Autolite XP Iridium or OEM copper plugs? TfcCDR V6 (1994-2004) Mustangs 0 09-12-2015 05:13 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
2006, 46l, additive, display, drill, fail, foams, ls1, lucas, mustang, oil, stabilizer, stablizier, supercharger, triton, vortech
