Fluid recommendations
I have a 2011 Mustang V6 which will be 5 years old in March. It's been trouble free although the MT82 manual transmission can be a bit notchy especially in cold weather. The car has about 27,000 mile on it. Since new I have changed the oil every 6 months and have used Mobil 1 5W-20 consistantly.
My question is now that the car is approaching 5 years with 27,000 miles, what fluid changes (other than the motor oil) should I be considering. Things like coolant, manual transmission fluid, rear end, etc?
Any advice would be appreciated. Also any recommendations on fluid brands to use would also be helpful.
Thanks.
Thanks.
Five years/27k a little early for trans and dif-I would do the others.If you feel ambitious,then do them all.
Just the nature of the trans to feel notchy when cold.These aren't BMW smooth as butter units.A fluid change or special potion won't change that.
I would absolutely change the fluid in the MT82 ASAP. Biggest bang for the buck mod you can do on these things, trust me. I highly recommend Amsoil as well, I did the "cocktail" that's recommend by a large group of folks on other forums and on Facebook which was 1qt Amsoil Synchromesh and 2 quarts Amsoil 75w90. Night and day difference in shifting.
I bought a 2016 Mustang a year ago with 32k on it and who knows what the previous owner put in it but I swapped out all the fluids using this page as a guide
https://www.searchforparts.com/oil-c...mustang-5.2l-z
Also, brake fluid as previously mentioned is a good idea. At the end of the day, it is up to you which brand you choose but I would replace all fluids with the best brand available after researching the quality of the fluid.
Good job with that!
Demon 340
01-06-2016 02:39 PM
Mustang Videos
12-19-2015 02:37 AM
