Other Professional Racing NASCAR, Formula 1, Sprint, Rally & Off Road, SCCA Auto X, Le Mans, Pro Stock, Cart, Drag, IROC, etc.
nascar engines
Old 02-28-2005, 10:13 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: nascar engines
just concider in the 80's the cars were running over 220......it takes a great valve train to run 8500+ for hours and the heat cycles on the engine is admazing..this is why they use sodium filled valve and there thermo coated......it they incorp.. the new spring coming out you will see 9K= rpms all day long..if they could put a 1050 like yester year.... speeds would be off the charts.........there is a fine line to where the engine will like rattle apart
vfast is offline
Old 03-29-2005, 12:28 AM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
ORIGINAL: Dan02GT
They could get more power within the rules, but it's just pushing it too much. If they could use whatever parts they wanted in their 357, I'm sure they could get well over the 900hp mark.
Crazy thing is, they are now turning over 10,000 rpms on some tracks... [&:]
ALL the time. 10,000 is considered "normal" now. With a single cam and pushrods!!!
They were turning 10,000 at Daytona this year.
MikeHawke is offline
Old 04-13-2005, 03:50 PM
Justin_Bradley
Justin_Bradley's Avatar
ORIGINAL: OICW
ORIGINAL: fast83gt
They only have to last one race. I'm sure you could get allot more power out of you engine if you only wanted it to last for 500 miles.
There's a difference between lasting 500 miles and redlining it for 500 miles, 4 hours.
4 hours of full throttle run! Nascars average 10 s in the 1/4 mile, so 4 hours full throttle is the equaivalent of: 3600s / 10 * 4 = 1440 1/4 mile passes!
Now imagine a engine making 1440 passes, sounds even more impressive now?
It's easy to make a crazy engine that cruises at 2000 rpm for 500 miles, but that's not what nascar engines do.
Actually the 1/4 varies on which track the car is set-up for... Car and Driver tested out one of Mayfield's cars liek they do production cars, just for fun, and it ran about 13.8s... they also completely destroyed 3 or so clutches trying to dump it on launches.
Justin_Bradley is offline
Old 04-15-2005, 05:42 AM
Mustangood
Mustangood's Avatar
ORIGINAL: Justin_Bradley
ORIGINAL: OICW
ORIGINAL: fast83gt
Ya it depends on the gears in the car, cuz they chance em depending on what kinda track theyre gona race at. They can run as quick as 10s or as slow as 13s.
Mustangood is offline
Old 04-18-2005, 11:44 PM
OICW
OICW's Avatar
With only 4 gears to play with and a 200+ mph top speeds, most setups would be crappy for acceleration. In the June 2000 issue of R&T, they had a properly setup Nascar for the 1/4 mile and it went into the 9's trapping over 160.
With a superspeedway gearing, you'd have to slip the clutch all the way to 60 mph or so. But try a roll-on with a Nascar if you're less than 900 hp you'll get destroyed.
OICW is offline
Old 07-02-2006, 05:47 PM
Jamie55
Jamie55's Avatar
Just read an artical the engines are between 350 cdi and 358, 750+ hp but with restricitor plates about 397hp. Still I would kill to have one of them engines in my Stang. WOOOOOOOOOOOOOOOOOOOOO
Jamie55 is offline
Old 07-02-2006, 05:57 PM
Jamie55
Jamie55's Avatar
Just in case anyone is interested http://www.digitalcad.com/Htm/FieldReports/nascar.htm that is the link about NASCAR engines. Pretty good read. Enjoy!!
[IMG]local://upfiles/34803/8BD22BD640F04DD99EF3B664FB18C34A.jpg[/IMG]
Jamie55 is offline
Old 07-03-2006, 02:42 AM
86_GT_Mustang
86_GT_Mustang's Avatar
ORIGINAL: fordguy17
ORIGINAL: Mustangood
I think Formula1 engines are amazing. They have like 3 liter v10s. They Idle at 8000rpm and have like 18000rpm redline
yup. they have a very short stroke.
and their like a half a million dollar go-cart.
86_GT_Mustang is offline
Old 07-13-2006, 06:53 PM
05BlackPony
05BlackPony's Avatar
..Just some more specs
http://www.joegibbsracing.com/curren.../wc_20_car.php
05BlackPony is offline
Old 07-13-2006, 07:08 PM
lookinforastang
I ♥ Acer
lookinforastang's Avatar
they dont cost $1,000,000++ for nothing
the suspensions in them are also what aid their high speeds and corner carving capabilities.
a nascar on the street would just apsolutely dominate anything except maybe a haybusa? who knows!
lookinforastang is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: nascar engines
