Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Safest nitrious system
Old 02-20-2004, 01:09 AM
CrazyHorse234
CrazyHorse234's Avatar
Default Safest nitrious system
What is the safest system on the market i have a few miles on my motor (90k) and id like it to last a bit longer
CrazyHorse234 is offline
Old 02-20-2004, 06:52 AM
Silver4.6
Silver4.6's Avatar
Default RE: Safest nitrious system
Most new nitrous set ups are all pretty safe as long as they are set up properly, and your car is tuned and you dont abuse the nitrous.
Silver4.6 is offline
Old 02-20-2004, 07:42 AM
Quik
Quik's Avatar
you can get away with a small dry kit upwards of 100 hp shot. safetest bet for a stock motor on dry. make sure you run high octane and retard the timing if possilbe
Quik is offline
Old 02-20-2004, 11:55 AM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
ORIGINAL: ohsoquik02
Why a dry kit when he can run a Wet system, go for the Wet kit and you can go as high as 125 Hp shot..
N2OJunkie is offline
Old 02-22-2004, 01:47 PM
stang574
stang574's Avatar
The "safety" of a nitrous kit is determined by the user. However, let me explain a drawback to a wet kit. If the kit is installed so that the nitrous and fuel mixture is injected upstream of the throttle body and upper intake plenum then a problem can arise. The intake plenums on mustangs were never design to transport a liquid or liquid vapor through its runners. This is more of a problem on the 5 liter engines due to the upper intakes design having the charge enter through a center runner and then make a 180 degree abrupt change to be distributed into the individual runners. At this critical turn the nitrous and fuel vapor tends to gather up at particular places and then feed the center runners more than the outers’. Another factor that comes into play here is that Nitrous and gasoline have different molecular weights. The nitrous has an easier time making the turn in the upper plenum, while the gas tends to lag behind. These problem can cause some cylinders to essentially run slightly lean. Cylinders 4 and 5 seem to be more susceptible than others. This problem becomes exponentially worse as higher power levels are required. I'm not saying dry kits are safer, I’m just merely stating a problem with larger power level wet kits.
stang574 is offline
Old 02-22-2004, 03:15 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
The "saftest" is a wet kit since it adds the additional gasoline along with the nitrous, instead of relying upon the stock fuel system to meet the demands. Clogged filter, locked up injector, and it's bye bye motor.
There is no safe kit on the market with a user that does not know it's limitations or have respect for the system.
jeep45238 is offline
Old 02-22-2004, 04:37 PM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
well said man...........
Old 02-24-2004, 06:57 AM
Silver4.6
Silver4.6's Avatar
jeep whats with the whimpy .22??? I think I shot those things when I was like 4
Old 02-24-2004, 08:54 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
I think it would take about 30 to severely **** someone up, and I wouldn't mind being the administrator of slow inevitable painful death like that
I may be switching over to my shottie soon.
Old 02-24-2004, 06:17 PM
Silver4.6
Silver4.6's Avatar
haha if your goin for the slow death your right on! deff take the shottie over the 22 though, I shot out 12guage moshburg (have no idea how to spell it!) when I was like 14 and loved it....sure did feel pretty bad ***!
Quick Reply: Safest nitrious system
