Exhaust or emissions, what is it? HELP
I need some help!!!
After just replacing my exhaust from the cats back on my 86 GT I happen to notice a loose tube, about the diameter of a nickle, which ties into both exhaust pipes just before the H-pipe. The pipe runs all the way up to a series of vacum control valves inside the engine compartment then it looks like this tube mounts to the rear of each head near the firewall.
What is it?? Do I need to replace it or can I bypass it if its not needed.
Someone please give me a clue.
RE: Exhaust or emissions, what is it? HELP
you cant elminate the smog pump line...it would blow **** into your engine compartment. however, you could elimiate the smog pump, but if you have emissions where you live, im not sure if you would pass
Could I seal off the lines on the exhaust side and also the line going to the heads, remove the pump and seal off all the vacume lines??
Do I need this system working for the car to run properly?
I believe it pushes fresh air in to reduce the overall percentage of emissions out. (by diluting it) If you bypass it or block it, you are only hurting your emissions.
mrappe
09-26-2015 10:16 AM
09-24-2015 09:18 PM
