Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
wastegates
Old 08-17-2006, 11:41 AM
maverick771
maverick771's Avatar
Default wastegates
Im buliding a twin turbo setup do i need to run 2 10psi wastegates or 2 5psi wastegates to have 10psi of boost...Also do i need both a wastegate and a bov
maverick771 is offline
Old 08-17-2006, 05:22 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: wastegates
you need two waste gates at 10psi that way each turbo stops making boost when the car hits 10psi. if you ran two 5psi waste gates, the the waste gate would open up as soon as the motor had 5psi slowing each turbo down.
yes you need a blow off valve. the bov is there to release boost air from the front of the tb when you let off the gas. without one its possible to damage the tb and the turbos. make sure the bov is before your blow through maf
luckythirteen13 is offline
Old 08-17-2006, 05:48 PM
maverick771
I dont have a maf its a carb but ive had it fixed for blow through.. but i understand what your saying thats what i thought but ive had a few people tell me that i didnt need both
Old 08-18-2006, 03:31 AM
luckythirteen13
a waste gate and a bov are too complete unrelated things. a waste gate controls how much boost the turbo makes. a bov releases boost in the intake when you let off the gas
2015Ecoboost
09-17-2015 01:48 PM
nismotunedgtr
4 Cylinder NA and Turbo
12-29-2006 02:08 PM
TBird232ci
61
11-20-2006 05:54 PM
Thumper33
10-03-2006 11:10 PM
dbayton
06-25-2006 11:41 PM
Quick Reply: wastegates
