supercharger
RE: supercharger
well i got the car back, and it WAS running like a champ. it was not the coil packs. the said it was a crank sensor that was dirty. they put in 3 gallons of 103 octane, and it ran fine till this afternoon. now after about 3300 rpms, puching it it stalls like something is holding it back. it is almost like it is not getting enough fuel. i know it is getting enough spark for sure. i have put the stock coil packs on and it is still the same. SO CONFUSED!
Hrm ...
If it were MY motor, I'd be doing a compression check. White smoke's never good. It sounds like a bad headgasket, or maybe even cracked/damaged ringlands.. but who knows. Do the compression check and tell us what the numbers are. If the numbers turn out cool, pull the heads and STILL check the ringlands for added insurance, or a piece of mind.. lol. I'd be a bit paranoid at this point. Hope everything turns out ok.. [&:]
RE: supercharger
engine is still stalling when i get on it. it starts to sputter, and then it gets ok. my check engine light came back on, and i took it to autozone for the check engine light deal. it said cylinder 1 misfire. i checked the plug and it was bent in. i regapped it and put it back on. took down the road and the same thing happened. it has got to be something i have over looked. it is not the coil packs because i put the factory ones back on. i have changed the plug wires. and all the plugs look good. PLEASE HELP.
RE: supercharger
Do you have an adjustable fuel pressure regulator and did the shop adjust it to increase the fuel flow under boost? you could be getting a lean misfire condition which can do engine damage if not corrected. worse case you might even need bigger injectors and fuel pump.
