lincoln 351??
lincoln 351??
hey i was wondering what you can tell me about howa lincoln 351 would do in an '85 stang?.....cause my stang doesnt have the 5.0L in it and my friends got a 351 sitting around and said that i could have it all i'd have to do is a rebuild and if i got a 5.0L i would probly do that anyway.......
lincoln 351??
Originally Posted by vfast
oooooooooooo HOT ROD LINCOLN!!!!
Take a look at the engine. I don't know about fords but dodge smallblocks have the distributor at the back of the motor behind and under the air cleaner. The big blocks have them up front. Perhaps Ford has some equally easy way to tell them apart.
lincoln 351??
A cleveland is not a big block,it's about the same size as a windsor,a BOSS 302 had cleveland cylinder heads on because they have canted valves and flowed better than other available heads at that time.The easy way to tell the difference between a windsor and a cleveland is the thermostat on a windsor is in the intake and a cleveland is in the front of the block,the 351m-400 engines are simular to a cleveland but have a raised deck.
