upper plenum
RE: upper plenum
Accufab makes the best one, but its also the most expensive. The aluminum crossover just replaces the plastic crossover that came stock and is only for reliability purposes - not performance - as the stock plastic cracks from the heat.
RE: upper plenum
I ordered the Trick Flow with matching 70mm throttle body from BBK for a little more than the price of the Accufab Intake, simply because the performance gains between the plenums are relatively the same. Accufab is the best though, even though its expensive.
