Twin Turbos?
#32
Twin Turbos?
Wastegate? The wastegate has absolutely nothing to do with what i'm talking about. It's simple physics. The exhaust leaving the cylinder bank with the larger turbo is going to have to spin a larger turbine than the other. More thermal expasion force is going to be required to turn it. Therefore exhaust will not be exiting as fast as the other bank. And since the engine is a glorified air pump and the amount of spent gases leaving has a direct effect on the amount of power it creates, the cylinders feeding the larger turbo won't produce the same power as the other cylinders. Once again do to the differences in the exhaust leaving. It would be the same as running duals, but having on side completley free flowing and the other has a dual cats and a muffler. Different exhaust pressures as measured at the exhaust valve.
#34
Twin Turbos?
Yea, thats a good idea but, I see a few problems with the setup. First, the smaller turbo is going to be easier to turn. This means as the rpms increase there gonna be a difference in the exhaust back pressure between the two cylinder head banks as measured at the exhaust valve. This will cause each side to be making different amounts of power.
And even my body with a built Eclipse has some turbo lag. Or take a ride in a stock eclipse and watch his boost guage go from a vacuum to boost. I've never rode in a turbo car and felt the same off the line acceleration as a blown car. Even if you put a turbo small enough to almost elimante turbo lag it would be so limited on the amount of air it could put out that.
With a turbo small enough to almost eliminate lag (2500 RPM full boost, ok?) you can make well over 500 horses and equal amounts of boost on a 302. T-3's are what I saw for this, but it was also an ongoing project that lasted around 5 years of engineering and fabrication.
One other thing about this motor. Alot of people only talk or stress about peak power numbers. A term you might have heard before is "power under the curve". It means the power that is made everywhere else but a peak levels. This motor would have so much power under the curve. Thats why it would be the ultimate street motor. Roots blown cars make instant power but tend to run out of juice at higher rpms. Turbo motors are just the opposite. They make power up high. Now put them together and you got the best from both worlds. Personaly, I would also use nitrous to cool the intake charge. A twice blown, juiced, 408 in a Fox body! Now where talking.
Well the problem with any turbo big or small is the dreaded turbo lag. Roots blowers are designed to make instant torque way low in the rpms. This blower would help in two very important ways. First it would eliminate all turbo lag. The motor I dynoed made seven pounds of boost at idle. When reved boost shot up with no lag like a lunar rocket. Second having this extra power from the blower engine would allow the turbo sizes to be much larger than normal. This would mean you would be making serious power when they really got cranking. The torque curve for this motor would start high and end through the roof. The motors efficiency would be up too, since the blowers power is driving the turbos rather than ending up out your tailpipes.
Some problems I see arising are parts breaking (I could see 1000hp out of this motor), Cooling the intake charge (1 big intercooler, 2 intercoolers, nitrous??), Cost (a whole lota parts and a whole lota money). I don't think making it all fit would be too hard. The twin turbo capri on www.toohighpsi.com wasn't really that hard to put the twins in. Just slap the blower on top and hold on because this motor would eat just about anybody up.
Twin turbo's can easily make all the power you're talking about (large turbos and they would have turbo lag. It's not mandatory to cool the intake charge, but you can tune it and get so much more power out of it if you do.
The only blown and turbo'd car I've seen was an 80's T bird, Pro Street, dual blower, dual turbos. It didn't run very smooth and it took months to tune right, but it ran mid 8's. Definately something most people can't afford or design correctly.
Originally Posted by Jugador
it's got to be easier to just get better suited twin turbos, and you can still get low end by having a smaller one to spool up quick, and a bigger one for the high end.
#36
Twin Turbos?
K Well i got lost at page 3 lol</P>
Summary:</P>
Turbo: pros- More HP (at low RPM or High RPM?) Easier to install? Cheaper? Come on guys back me up but cutt out the big words lol</P>
Turbo: Cons- Turbo Lag? But can be fixed. Dont know much about S/C or Turbo.</P>
SuperCharger : Pros- Ummmmm Not quite sure. No Lag?</P>
Supercharger : Cons- Ummmmmmmmm Like i said i dont know about this stuff.</P>
#37
Twin Turbos?
Turbo pros: more horsepower and more torque. all over the RPM range
Turbo cons: longer to install, more initial cost
Supercharger pros: cheaper and easier to install
Supercharger cons: Most are centrifugals, which require the motor to spool up to create boost......while a turbo could have been producing full boost for over 1000RPM.
#38
Twin Turbos?
The ONLY, ONLY way the two cylinder banks would make the same amount of power on this particular setup would be if the engine was running enough exhaust duration to completly remove all residual exhaust gases. This would allow the cylinders to equally take advatage of the forced induction. Also this motor would have to run no overlap to avoid the exhaust backpressure (which is normally greater than the induction pressure coming in from the intake valve) from staying in the cylinder. Most turbos run as little of overlap as possible but, regreatably have to run a slight amount due to limited crankshaft degrees available. AND after the turbine "spools up" the backpressure will get worse. As the exhaust leaves the port and begins building up pressure (which is initally needed to overcome the potential interia energy of the turbine) the turbine begins to spin. This percentage of exhaust leaving versus the turbine spinning will only get worse. As more exhuast leaves the port more pressure begins to build up at the turbine wheel. This allows the turbine to build up it's large speeds. It is this "trying to exit pressure" that drives the speed increase in the turbo. That is also why with two different turbine wheels and A/R ratios will create different exhaust pressures at the turbine (not refering the pressure after the turbine) You half to remember the pressure in the exhaust port from the exhaust valve tip to the turbine wheel (due to the laws of fluid dynamics) is going to stay as close to the same pressure as it possible can(because nature trys to equalize itself). And since each cylinder head is emptying its exhaust into different pressure enviroments it is HIGHLY unlikely that they will have the same cylinder exhaust leaving pressures and therfore their intake filling characteristics HAS to also be different. This will create the differences in power betweent the banks. I'm sure if we looked at the rpm increase after each cylinder fires we would see how one side is making more than the other. I know that the difference is probably not a great amount but it is inherently there. This may seem like a very **** thing to discuss and I agree it is. As I began looking at the sequencial turbo set up (about a year or so ago) I couldn't help but think of how these little details might of been overlooked or ruled out because the benefits overruled the negatives.
I have alot of respect for anyone who runs turbos or twin turbos. I just hope this will help show how what is on the market isn't always 100% correct. I also know how this can be very confusing if it is not thought about without being overly ****. Pleas excuse the long post and feel free to pick out anything you see incorrect.
#39
Twin Turbos?
NOOOOOT really......
You can never remove all residual exhaust gases without introducing overlap to blow intake air and knock out the exhaust, but you'll also loose the potential power gains doing it.
The reason being the only way to get a VE of 100% is to introduce metal-metal contact and make no room for any air.....which we all know is gonna f**k up the motor very quickly doing that.
Agreed most boosted motors, be it turbo or super run as little overlap as possible because they want to kep the boost inside the motor and not **** it out. But disagreed on the part of theexhaust backpressure being greater than the induction and keeping it inside of the cylinder. STRONGLY disagree.
The backpressure really isn't caused by a spooling turbo (they run off of the heat in the exhaust much more than the pressure of it). The bearings spin pretty freely.
Believe me, I don't care if it's very **** to discuss, it's in my nature. Looking forward to some debating and learning, hopeuflly for both of us.
#40
Twin Turbos?
So let me get thsi straight supercharger is more for like race tracks or is that turbo?</P>
Ok this is my case, say i get a mustang or a decide to upgrade my f150 i drive normal around city and i drive 80-90 on freeway. Sometimes i do go fast and i gun it just for the fun of it. In my case what is better? A supercharger for my truck is 4100 its a 97 F-150 ext. cab. And for my mustang i dont know because it will either b a 03+ possible a 05. What would be great for a old 69 Boss 429? or a 302? I know they use high HP i would love to drag with it, but i dont think the pssst pssst pssst sound would b great for a domestic engine liek that. Suggestions?</P>
